PS4 no power after enabling UART
  • Guest
    Hi, I have a PS4 Slim that shows no power after I tried to enable UART.
    Before this it was working fine except for the disc drive.
    I removed the NOR flash, patched the dump to enable UART and put it back on the motherboard.
    After this process the PS4 acts like there's no power. I tried the power button, inserting a disc and using the joypad. No beeps/no leds.
    It was my first time attempting this so I'm afraid I broke something on the motherboard while using the hot air station, but I can't see any obvious problem or missing component.
    • I checked the caps around the flash for shorts to ground and they look good
    • 12v, 5v rails are not shorted to ground
    • NOR VCC not shorted to ground
    • PSU is working fine in another console
    • NOR flash is still good, I desoldered it again and was able to read its content
    • Writing back the original NOR flash dump didn't fix the issue
    What else should I check?
    Thank you!
  • Guest
    Re: PS4 no power after enabling UART
    Update on the situation:
    I've been sick the last couple of days so I didn't look too much at the console. Today I picked it up again and connected it to a TV, and everything is working fine.
    I'll monitor it for a while but I'm still curious about what could've caused the no power issue
    • scorpionfadi
      • Mar 2018
      • 6
      • syria
      The problem with ps4 is that the source bridge is damaged. You need to replace the chip so that you can boot the device. and see the uart .
      What type of board for your device؟؟؟
      i can help you.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! 🚀
        I have no idea what I’m doing, but I’m learning by trial and error.
        I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
      • mkdj
        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
        by mkdj
        Dear all,
        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
        Both N-Channel Mosfets: nothing odd
        P-Channel MOSFET number 1:
        source - drain : 117 kOhm
        source - gate: 96 Ohm
        gate - drain: 117 kOhm
        P-Channel MOSFET...
        08-20-2025, 06:08 AM
        03-31-2024, 02:12 PM
