Peugoet 307 KEY Blip MOTHERBOARD
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    This circuit is for a remote control for a peugoet307 there are short on two smd capacitor marked on the last picture (20230815-182713) one black green has not seen reached like that before maybe someone can enlighten about it
    • 31247
    Re: Peugoet 307 KEY Blip MOTHERBOARD
    camera needs a macro setting or an extra lense - the images are out of focus
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      thanks how about them here
        • 31247
        i think the red ones are caps,
        the green thing is interesting, maybe a fuse or diode?
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          stj please I don't see any red here but the green probably more diode or capacitor than fuse because in car remote control there are usually no fuses.
            • 31247
            i know a fuse makes no sense with a coincell driven circuit.
            what is actually wrong?
            the green mystery looks o.k. visually.
            the usual fault on these type of things is the buttons
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              The problem with this is it has no contact with the car plus that the two capacitor that is circled in them first bad pictures are short I have removed both but it is the same on the tracers and I do not find any connection on the circuit
              • redwire
                • 3912
                Uh which two capacitors? I can see nothing marked in the pictures. There would be a short across the white ones for RF tuning, that is normal.
                The ceramic green part is odd and it has a polarity stripe. There's no need for a temperature or water sensor, or trimmed resistance or capacitor. That leaves an inductor but no need for the stripe. It's some specialty part.
                The RF TX IC K110 looks NXP, and the NFID IC looking too fuzzy to make out the part number.
                Repairing these, I find it's dirt/spilt coffee, bad switches. The battery holder can also get bent/mangled.
                I will scrub with IPA and a toothbrush, then resolder any cracked joints. Cracked capacitors is harder to find.
                One side of the board is the RF remote TX, the other side key NFID.
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  That's right, the picture is not included because it was too big.
                  The two capacitor I meant are the black-green and the first
                  in the narrow edge the two have continuity oh short is kar after i train them away and what can i replace the black green with
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
