PS5 Wont update stuck 99%
  • Meraxes
    • Mar 2023
    • 5
    Ps5 version with disk version 1.1 everything seems to work normally but you can't update when installing it blocks at 99% without any error, any suggestions? I would appreciate it thanks
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • Meraxes
    Ps4 Slim firmware update stuck on 53%
    by Meraxes
    I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
    Hdd is ok, it is tested with hdtune pro
    The Blu-ray worked perfectly before the update
    I tried several USB flash drives, no change
    The wifi module was changed does the same
    Can someone help me ? can the southbridge have problems?
    03-07-2023, 09:37 AM
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
