Steam Deck 14.3v 0amps
  • bogosort
    • May 2022
    • 78
    I have this steam deck that has no current draw. I did a visual inspection and found nothing.
    No dead short either, but these caps show 20-30ohms.
    Any idea where to start? Thank you!
    EDIT:
    Noticed something with voltage. Is the component in green faulty?
    • 31020
    Re: Steam Deck 14.3v 0amps
    what is the white staining? liquid spillage?
    • bogosort
      • May 2022
      • 78
      Looks like thermal paste, I have no idea.
      Upon continuing diagnosing, I have found some pins on the charging IC that have 0.2ohms to ground.
      Here is the IC: https://cdn.badcaps-static.com/pdfs/...b3d10ef42c.pdf
      Is it normal if these pins are shorted to ground? Others are too, but I'll start with these :
      Circled in blue
        • 31020
        the thermal paste is pink,
        the white stuff is all over a buck convertor circuit!
        • bogosort
          • May 2022
          • 78
          I have to scratch to remove it. Do you think it could be metal liquid paste, but then later replaced with pink thermal paste?
          I'll try cleaning with alcohol
            • 31020
            those pins may be o.k. - 7,8 & 10
            does this have a battery or just external power?
              • 31020
              it's not liquid metal (galium), that would disolve aluminium and probably solder
              • bogosort
                • May 2022
                • 78
                I have both external power and battery.
                Original owner said it stopped charging after changing SSD.
                The steam deck continued working until the battery died, because it couldn't charge anymore.
                I read online that sometimes SSD can take more current than the chip is rated for, thus frying the charging IC.
                What do you think? How can I check if the chip is bad?
                Thanks!
                  • 31020
                  do you have the old ssd?
                  • bogosort
                    • May 2022
                    • 78
                    I actually don't have the other one, just the original ssd
                      • 31020
                      i asked because trying the original would be interesting - incase it works again.
                      • Jim Farid
                        Steam Deck: how to solder 3 pin POWER BUTTON with one missing (ripped-off) solder pad?
                        by Jim Farid
                        The middle pad (B) on my steam deck's power button got ripped off. I want to bridge the middle pin to a via or another pad but don't know which one. Do you guys know any?
                        The pads with the stars are all ground.
                        In case there's no pad I can bridge to, do you know how to turn my deck on without using the power button? Thanks a lot 🙏....
                        06-09-2024, 02:38 PM
                      • olane
                        Steam Deck Crystal Oscillator replacement part
                        by olane
                        Hi just wondering if anyone knew the part ID for the crystal Oscillator on the Steam Deck i've attached an image of the broken part on my board.
                        Thanks...
                        02-02-2024, 12:56 PM
                        ALIENWARE Steam R2 i7-6700T Specification for Upgrade or Repair
                        This specification for the ALIENWARE Steam R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam R2 boardview and Steam R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Steam...
                        09-12-2024, 03:28 PM
                        ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                        This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      • dustfilledhobo
                        Kenwood KX-56CW Duel Cassette Deck Repair
                        by dustfilledhobo
                        Hello!
                        I'm trying to fix my Kenwood KX-56CW dual cassette deck (seen in the picture below).
                        Everything functions as it should except that the motor for tape deck B plays back extremely fast (tape deck A functions properly). I've located the two trim pots on the board that control the speed of deck B and they were only able to bring the speed down a little bit. I was able to find a schematic online (attached) with suggested voltages, so I measured the board while playing a tape in deck B (as per the instructions on the schematic). Some voltages were...
                        04-11-2021, 11:52 AM
