Obrigado! Muito útil.
Boardview xbox 360 , xbox fat , xbox one x and xbox one s
Hi here the attachments . Xbox series x and s only shematics
Pasw is netcomchetumal
Hello I need the Boadview of the Xbox One Fat I can't get it can upload a link so that I can download?????????Leave a comment:
Did you try to open with flexboard there is also free version from. https://pldaniels.com/flexbv5/download.phpLeave a comment:
Theres also another source i recenty stumbled upon for 360 boardviews, but most boardview software refuses to work with these .brd files, schematics work just fine though.
https://xbox360hub.com/guides/Leave a comment:
Here's what ive run across controller-wise.Attached FilesLeave a comment:
ok meu amigo vou seguir seu conselho, ,valeu mesmo, muito obrigado e estamos juntos...Leave a comment:
by nicole77Looking for Boardview file for Xbox One S, Series S and also Series X, Please01-15-2025, 04:50 AM
by TMTGTRFirstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
=>Background:
I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ... -
by grimacelordHello,
Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox... -
I've got an Xbox One S PSU opened up. I'm not getting 12vdc output as I do with my test unit. I'm sure this board must have a fuse but I don't see it as everything on the board is poorly labeled.
I have problem with my graphic card GV-N3060GAMING OC-12GD.
2 smd elements are missing.
I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
This is my PCB
And this is screen of boardview
As you see those missing capacitors or resistors are not on boardview.
Also i compared every single transistor from boardview to real card and everything is related.
It seems that this one is like extra.
Could anyone...-
08-09-2025, 10:26 AM -
- Loading...
