Passat key fob component identification
  • ob1knobie
    • Apr 2021
    • 10
    • Ireland
    Hi
    In my stupidity i managed to pry off 2 components while disassembling a Passat key fob.
    I have uploaded a boardview (BVR) file and referenced missing as parts UNK1 and UNK2 Also uploaded is an image showing the components before flying into the 9th dimension.
    Boardview creation video is here:-
    https://www.youtube.com/watch?v=rDL0Ya47oz0
    Would anyone know the value and types of these 2 components.
    I would really appreciate it.
    Ob1
    • 30979
    Re: Passat key fob component identification
    capacitors
    the gray one is probably in the pF range
    • ob1knobie
      • Apr 2021
      • 10
      • Ireland
      With no donor board available and no schematic, is it possible these parts be identified?
      Ob1
      • Shulgin
        Acer predator XB241YU Component identification
        by Shulgin
        I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
        After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
        In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
        I...
        05-11-2024, 11:06 AM
      • thebomb602
        ASUS GA402R IC identification
        by thebomb602
        Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
        also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
        EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
        11-21-2023, 02:30 PM
      • Tend0
        hp elitebook 840 G4 no 5v IC identification
        by Tend0
        Hello everythone
        i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
        i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
        05-31-2025, 09:13 PM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • FrozenHaxor
        SOT23 component identification
        by FrozenHaxor
        Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
        04-09-2025, 03:17 AM
