Dell optiplex 3000 micro bios
  • volinakis
    • Jan 2021
    • 2728
    • N/A
    #181
    Originally posted by redcapangler
    Ok, I reflashed original bios again, confirmed the machine can still boot (success) cleared the settings - then reflashed the updated file you provided.
    The video came online (good, I wasn't waiting long enough for the reboots), i went into bios but the Absolute is still grayed out. Any thoughts?
    so it was about poor soldering... did you remove CMOS battery before soldering bios chipset? Try applying defaults and see if works.
    • redcapangler
      • Mar 2025
      • 20
      Hi - so i've verified soldering is not the issue (have successfully reflashed many times on this board now). I did remove the CMOS battery before soldering, no issues there. Chip is working.
      On a similar board (Optiplex 7010 micro) I required both the 16mb and 32mb chips to be updated in order for it work. hoaca388 helped with that one. I'm wondering if edits need to be made to the 16mb file as well?
      • volinakis
        • Jan 2021
        • 2728
        • N/A
        #183
        well, 1st time when you wrote the file I sent you, you said it wasn't work. 2nd time when you wrote it in bios chipset it worked ... so, where was the problem? 32Mb chipset contain Bios_Region so Computrace is in it, no need to modify 16Mb chipset usually but you seem to have also problems with ME firmware. So you need to do a clean ME to your full bios.
Name:	Screen Shot 2025-04-02 at 20.30.23.png
        • redcapangler
          • Mar 2025
          • 20
          I will try to do this myself and report back. First time performing an "ME" clean.
          • pronto
            • Mar 2019
            • 113
            • morocco
            #185
            I NEED UNLOCK PASSWORD
            OPTİPLEX 3000 MICRO
            ST:8XWK4V3
            REG MODEL D15U
          • Imdeksn99
            • Jul 2024
            • 22
            • Phillipines
            #186
            guys please help me to remove admin password on bios
            st: 4TJ0HY3
          • peste
            • Dec 2016
            • 12742
            • ROMANIA
            #187
            st: 4TJ0HY3
            post full name and model, motherboard model, etc.
            • Imdeksn99
              • Jul 2024
              • 22
              • Phillipines
              #188
              DELL OPTIPLEX 3000 micro PC
              • redcapangler
                • Mar 2025
                • 20
                Hi volinakis , I was unsuccessful and got stuck. I was able to install ME Analyzer, get the same output in you screenshot at the bottom when loading my 16mb file. When I go to find the right firmware (attached in screenshot), I does not seem that my version is available out there to use as a base file for the cleaning process. Do you know of anyone that has gotten their ME Cleaned with version 16.1.31.xxxx? I'm only seeing all the guides go up to version 15.x.x.
                Any help is appreciated, I'm really stuck on this next part.
                Thank you,
                - Brian.
                • redcapangler
                  • Mar 2025
                  • 20
                  Originally posted by hoaca388
                  Re: Dell optiplex 3000 micro
                  1111111
                  Is it possible I could just load the bios from this older post to resolve my issue? Or would that not work?
                  Thank you,
                  - Brian
                  • redcapangler
                    • Mar 2025
                    • 20
                    Thank you,
                    - Brian
                    I tried this and it did not work. I'm trying another bios from this thread for the 16mb to see if that one will work. Really stuck here.
                    • redcapangler
                      • Mar 2025
                      • 20
                      Did not work, posting my original files to see if someone else can assist? I'm looking to have absolute disabled in both of these files / cleaned ME please.
                      Service tag is JXHJ5S3
                      I've been struggling for about a month in this thread trying to get this fixed, any help is truly appreciated.
                      - Brian
                      • tlkdgb
                        • Apr 2025
                        • nederland
                        #193
                        Hello, my BIOS is all "LOCKT" Can you please help me unlock the bios?
                        any idea to fix this ?
                        OptiPlex 3000 Micro
                        Service Tag: 1119MP3​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11708
                          #194
                          - Brian
                          OptiPlex 3000 Micro
                          Service Tag: JXHJ5S3​
                          • redcapangler
                            • Mar 2025
                            • 20
                            hoaca388 - these worked perfectly. Can you explain how you performed modifications to the 16MB file to clean the ME especially with version 16.1.32? Or can you point me toward any other resources on how you did this?
                            Thank you,
                            - Brian
                            • Imdeksn99
                              • Jul 2024
                              • 22
                              • Phillipines
                              #196
                              OptiPlex 3000 Micro
                              HELLO CAN YOU HELP MINE THIS WAS MY ORIGINAL BIOS
                              SERVICE TAG:4TJ0HY3
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11708
                                #197
                                SERVICE TAG:4TJ0HY3
                                You problem is ????
                                • Imdeksn99
                                  • Jul 2024
                                  • 22
                                  • Phillipines
                                  #198
                                  You problem is ????
                                  bios password lock sorry i didnt mention
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11708
                                    #199
                                    Unlocked
                                    • Jeroentje
                                      • Dec 2017
                                      • 82
                                      • Nederland
                                      #200
                                      I have no password issues but no image, tried some bios files from here but no result, diffrence is that with 16mb file from here the fan get's to 100%
                                      no image system will take 10 watts and chipset is getting 45-50 degrees.
                                        SMDFlea commented
                                        Editing a comment
                                        Service tag ?
                                    • Altemon Moura
                                      Optiplex 3000 micro
                                      by Altemon Moura
                                      Unfortunately, when removing the chip
                                      (GIGADEVICE 25R256EYIG)
                                      It broke in the hot air.
                                      Will I be able to buy this same model?
                                      (GD25R256EYIG)
                                      "Can I burn the Bios?"
                                      motherboard
                                      DELL Optplex 3000 - 202040-1 D10NK$HA
                                      Optiplex 3000 micro
                                      Service tag: C7CG7T3
                                      SERVICE CODE: 26565563271​
                                      05-20-2025, 06:35 AM
                                      DELL OptiPlex 3070 OptiPlex 3000 i3-9100 Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:44 PM
                                      DELL OptiPlex 3040m OptiPlex 3000 i5-6500T Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      DELL OptiPlex 3070 OptiPlex 3000 i5-8500 Specification for Upgrade or Repair
                                      DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
