dell optiplex 3090 bios issue please help!!
  • Arrow16
    • Apr 2022
    • 229
    • Philippines
    Re: dell optiplex 3090 bios issue please help!!
    One of these files should fix your Problem.
    Thank you sir
    • 3NCRY9T3R
      • Jun 2023
      • India
      Need bios unlock file
      Serial no. : CB26KN3
      Along with the steps please.
      • mhttarde
        • Sep 2018
        • Konya
        DELL OPTİPLEX 3090 CHDP9N3 there is a bios password does anyone have a solid file
        • jhaydee14
          • Jun 2023
          • philippines
          Help dell optiplex 3090 need absolute computrace to disable, but it is locked in the bios,
          Service Tag: CR294K3
          Thanks in advance.
          • Arrow16
            • Apr 2022
            • 229
            • Philippines
            Need help dell 3090 mini absolute lock hope someone can help tnx...
            Service tag: 60SPVP3
            • Arrow16
              • Apr 2022
              • 229
              • Philippines
              #26
              Up
              • yuri3185pcnet
                • Jul 2019
                • 12
                • Philippines
                #27
                Good day can anyone remove Absolute in my dell 3090
                Service Tag: 7MJW6L3
                THANKS in advance.. Your help is truly appreciated.
                • Arrow16
                  • Apr 2022
                  • 229
                  • Philippines
                  #28
                  Upload backup bios, i will help you, i found a way by myself
                  • yuri3185pcnet
                    • Jul 2019
                    • 12
                    • Philippines
                    #29
                    Thank you sir @Arrow16..Here is my back up file thanks alot.
                    • Arrow16
                      • Apr 2022
                      • 229
                      • Philippines
                      #30
                      Giv feedback... Enjoy
                      • yuri3185pcnet
                        • Jul 2019
                        • 12
                        • Philippines
                        #31
                        Thank you very much sir..I will test it later..Cheers, God Bless...
                        • yuri3185pcnet
                          • Jul 2019
                          • 12
                          • Philippines
                          #32
                          Good eve sir Arrow16, thanks for the firmware I test it but still have absolute enable ..
                          • Arrow16
                            • Apr 2022
                            • 229
                            • Philippines
                            #33
                            Here try give feedbacl
                            • yuri3185pcnet
                              • Jul 2019
                              • 12
                              • Philippines
                              #34
                              Thank you sir it works I permanently disable the Absolute..Thanks you very much sir,..pm kita sir,thanks
                              • jhaydee14
                                • Jun 2023
                                • philippines
                                #35
                                Good Eve Sir,
                                How could i create a back up file (bin) bios for optiplex 3090 micro.
                                • skymoon83
                                  • Oct 2015
                                  • 11
                                  • izmit
                                  #36
                                  help bios password issue, Dell OptiPlex 3090 Small Form Factor.
                                  Servis TAG: F9DP9N3
                                  • elmotastic
                                    • Jun 2023
                                    • 3
                                    Hope you are doing well. I have an admin password locked Optiplex 3090 Micro and was able to extract the locked bios with a CH341a and a SOP16 clip.
                                    Would be really nice if one could unlock my Bios file.
                                    Kind regards, Elmotastic
                                    • volinakis
                                      • Jan 2021
                                      • 2738
                                      • N/A
                                      #38
                                      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                                      • volinakis
                                        • Jan 2021
                                        • 2738
                                        • N/A
                                        #39
                                        Servis TAG: F9DP9N3
                                        • elmotastic
                                          • Jun 2023
                                          • 3
                                          Originally posted by jhaydee14
                                          Good Eve Sir,
                                          Just a short summary what worked for for my dump. I purchased a SOP16 test clip and soldered the eight wires to it. Actually I purchased another one pre-wired that did not create a stable dump.
                                          With an CH341a Pro set to 3.3V I was able to create a dump with flashrom on Linux and write the patched one. I had to remove all components from the board.
                                          The wiring was simply taken from the chips datasheet:
                                          https://cdn.badcaps-static.com/pdfs/...0d14ff4525.pdf
                                            DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL OptiPlex 3090 OptiPlex 3000 i3-1115G4 Specification for Upgrade or Repair
                                            09-12-2024, 03:36 PM
