FOXCONN G41M02S1 Need Bios
  • yomal66
    • Jan 2022
    • 26
    • Sri Lanka
    FOXCONN G41M02S1
    Need Bios
  • peste
    • 13421
    • ROMANIA
    Re: FOXCONN G41M02S1 Need Bios
    Originally posted by yomal66
    FOXCONN G41M02S1
    Need Bios
    post the name, full model and original bios of the laptop even if it's corrupted
    • yomal66
      • Jan 2022
      • 26
      • Sri Lanka
      its desktop mother board.
      • Lisa Su
        Badcaps
        • Apr 2021
        • 216
        • Taiwan
        Extracted from official updater
        • yomal66
          • Jan 2022
          • 26
          • Sri Lanka
          thank you
          • FalconPunch
            Surface Pro X 1876 Bios corrupted
            by FalconPunch
            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
            08-09-2025, 03:56 AM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • grimacelord
            by grimacelord
            Hello there.
            History:
            03-15-2023, 03:29 PM
          • TylerHyde21
            Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
            by TylerHyde21
            Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
            I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
            I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
            This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
            06-29-2024, 10:38 AM
