Asus VivoStick TS10 - no picture
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Hi friends.
    I've got uncommon PC to fix from friend - Asus VivoStick PC TS10. PC has no picture after automatic windows update ( PC was tuned off normally ).
    Everything looks fine to me ( 5V on USB ports, new CMOS battery, power button works fine, cpu is warming, 100mA power consumption when turned on ), so first thing I did was flashing new BIOS from official support. It didn't help, same behaviour. But original dump looked completely different to a new one ( even to older ones from official site ), and was shorter a bit.
    Can someone of you take a look on the binaries, if it is OK? Or if it is even BIOS related issue? The biggest help to me would be of course BIOS dump from someone with the same device. Thanks in advance.
    Link to official assus site with latest ( actually flashed ) BIOS firmware: https://www.asus.com/Commercial-Mini...HelpDesk_BIOS/ ... Version 0609
    My bios dump in attachments.
  • peste
    • 13566
    • ROMANIA
    Re: Asus VivoStick TS10 - no picture
    Originally posted by YellowJacket
    Hi friends.
    bios extracted from Asus website update...
    • YellowJacket
      • Dec 2020
      • 105
      • Slovakia
      Thank you a lot, peste. I did stupid mistake, flash that CAP file directly. Didn't know, it has to be extracted.
      Everything works now, after few restarts, thank you a lot.
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
