Asus z390-1 rev 1.02
  • pooya_pm
    • Jan 2021
    • 258
    • iraq
    I need working bios for asus z390-1 rev 1.02
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: Asus z390-1 rev 1.02
    https://rog.asus.com/vn/motherboards...helpdesk_bios/
    • WhyINeedAccount123
      • Feb 2021
      • 19
      • Poland
      there is no working bios for this motherboard, why you link it??
        • 21841
        Download the bios from the support page,extract from the zip folder then open the *.CAP with UEFITool , select "Action - Capsule - Extract Body" that will remove the CAPsule header leaving you with the 16,384KB 16MB bios .Rename it from *.ROM to *.bin if you like, its the same thing.
        https://github.com/LongSoft/UEFITool..._A57_win32.zip
          • Feb 2021
          • 19
          • Poland
          I did as you said but no response. Then the computer turns on without a picture, when turning on the cpu LED lights up, then the dram LED. Then the vga and boot LED should light up but it doesn't. Still not working
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • rayshine03121408
            I Need Working BIOS for ASUS E410MA R7.1
            by rayshine03121408
            Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
            Model: ASUS E410MA-TB.CL464BK
            SN: N8N0CX06E199324
            BoardModel: E410MA R7.1
            08-26-2025, 05:36 AM
          • rockman97
            Asus TUF X570 GAMING PLUS Motherboard BIOS fix
            by rockman97
            I had my old motherboard i really want build a HTPC and i want use this mobo but i tried BIOS update in 2024 and the motherboard is cooked it get orange led only tried change cpu ram everything but can't fixit. (I bought the motherabord second hand in 2023.)
            It has a Winbond 25Q256JWEQ (I think this is a 1.8V model so i used the 1.8v adapter aswell.) Bios chip on it i tried reflash with my EZP2019+ programmer but when i manually choose a chip like similar to this i click the read button and only shows 000 and i can erase it when i try write i can't verify it.
            I...
            08-24-2025, 01:01 PM
          • eastcoastcomputing
            Please help Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1) Bios
            by eastcoastcomputing
            Hi there,
            I have an Asus G713QY that won't boot. The machine fire up to a black screen, no post but everything seems to check out on the board. I believe the motherboard needs the bios reloaded but I can't find the bios file. I've looked on the Asus website but what is available for download is the .exe to run in windows (which won't help). I've tried to unzip it but can't see the bios file that I need. Can anyone share the bios file for an Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1). Thanks
            02-21-2024, 04:32 AM
          • fauxkalel
            ASUS Vivobook P1504F X512FA (MB X512FF) Working BIOS with DMI/SN
            by fauxkalel
            MB X512FF rev. 2.2
            i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
            I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
            Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
            SN: L1NXCV10B90903C...
            10-29-2024, 03:34 AM
