ASRock H81M-G v1.01 - i need Clean ME, please
  • c.daniel
    • Mar 2017
    • 108
    Hi guys; i have this mainboard, and i have some problems with her:
    1. it shutdown randomly
    2. if i let her shutdown and out of power supply, the next morning will power on only after i made an bios reset from jumper
    I do all the changes, cpu, ram, power supply, i even update bios from 1.20 to 1.30, then to 1.40 and last, to 1.50, wich is the last bios vs from asus. I clean with izopropilic alcool all contacts from cpu, ram, sata, pci express. Mainboard is very clean. No pin from cpu socket is bent.
    After is power on, it's working perfect, sound, lan, all are in perfect order.
    So, i want to try a Clean ME, just to be sure that i try all my best, before i give up on her.
    So, anyone if you can do for me a Clean ME, it will be great; thanks a lot.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: ASRock H81M-G v1.01 - i need Clean ME, please
    https://www.asrock.com/mb/Intel/H81M-G/#BIOS
    Latest virgin bios with clean ME region.
    • gabrieljma1
      Request: Full BIOS dump for ASRock Z790-CX (DDR5)
      by gabrieljma1
      I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
      The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
      I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
      10-08-2025, 03:32 PM
    • Mirenia
      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
      by Mirenia
      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
      03-30-2025, 06:47 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • kacangpolo
      Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
      by kacangpolo
      I have problem with my laptop, with code board X415EA 2.0,
      laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
      I did :
      1. Flash Bios
      2. RTC_RST 3.3V
      3. LID_SW 3.3V
      4. WLAN_WAKE# 3.3V
      08-26-2025, 04:42 AM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
