dump bios for hp desktop ATAYAL REV 1.00 FXN1
  • paulweb890
    • Jul 2015
    • 6
    • Italia
    hi all, i'm looking for this dump for hp ATAYAL rev 1.00
    Thank you!!
    • 21845
    Re: dump bios for hp desktop ATAYAL REV 1.00 FXN1
    Thank you!!
    Post the full PC model number, the PC serial number and your bios backup.
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
