A320M Pro-VH Plus
  • kulokutoys
    • Jun 2010
    • 132
    • Phillippines
    A320M Pro-VH Plus
    need bin for this mobo MS-7B07
    • 21417
    Re: A320M Pro-VH Plus
    For retail motherboards always check the support page,the full bios is usually available. The latest bios is named E7B07AMS.3I3 ,just rename it to E7B07AMS.bin
    https://www.msi.com/Motherboard/A320...H-PLUS/support
    • kulokutoys
      • Jun 2010
      • 132
      • Phillippines
      thank you
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • andrestecno
        BIOS upgrade fail mother GA-A320M-S2H (rev. 1.2)
        by andrestecno
        Hi, my USB ports were hanging every now and then when starting up. So I decided to update the BIOS of the mother. Unfortunately, after finishing the flashing through QFLASH with a pendrive of the latest firmware version, the cooler turns on, black screen and seems blocked.
        Model: GA-A320M-S2H (rev. 1.2)
        Processor: AMD A8 9600
        Previous BIOS version: F53
        I downloaded the F58d version from here (I think it's the correct one)
        https://www.gigabyte.com/ar/Motherbo...upport-dl-bios
        Is there anything that can be done?...
        09-11-2024, 11:34 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
      • Ibod
        Corsair cx600 psu & ASRock B450Pro4 mobo wont start
        by Ibod
        HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
        With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
        Not sure where to go from here ?
        Is the PSU at fault or is the mobo causing the problem
        Look forward to any help :-)
        If I plug the 24...
        02-08-2023, 11:00 AM
