Help HP PRODESK 600 g6 mini bios file
  • peste
    • Dec 2016
    • 12274
    • ROMANIA
    Re: hp prodesk 600 g6 mini pc 35W bios locked
    Originally posted by charlie0816
    no luck for rc unlocker tnc
    https://www.badcaps.net/forum/showth...ght=rcunlocker
    • bbanana
      Father Land
      • Oct 2021
      • 158
      • Vietnam
      try this
      • bokak1
        • Feb 2023
        • 3
        • Bosnia & Herzegovina
        Re: Help HP PRODESK 600 g6 mini bios file
        Clear my bios pass please!
        • hoaca388
          Badcaps
          • Jan 2022
          • 11225
          • Viet Nam
          Your rar file corrupted, check it.
          • bokak1
            • Feb 2023
            • 3
            Please can You clear my bios!
            • hoaca388
              Badcaps
              • Jan 2022
              • 11225
              • Viet Nam
              #26
              Unlocked
              • bokak1
                • Feb 2023
                • 3
                #27
                thanks, but bios has a password again!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11225
                  • Viet Nam
                  #28
                  Post file from 2nd SPI chip.
                  • Greg_E
                    • Apr 2023
                    • 6
                    Please excuse the newb questions...
                    What software and hardware are people using on these HP computers?
                    I have an HP 600 G6 SFF that I need to clear the BIOS password. I've tried an EZP2019+ and that wont read the MX25L25673g BIOS chip. I just ordered a CH341a v1.7 with the voltage switch and hoping I have better luck with it.
                    Yes I have the correct 16 pin clip to hopefully do in circuit programming (hopefully).
                    Also any good guide to this whole process? I want to learn to do this, not just ask for someone to unlock my "stuff".
                    Again sorry for the newb questions and slightly (kind of) off topic. I think this is the same chip as the 600g6 mini in this thread and the closest I've found through many sessions of google searches.
                    • Greg_E
                      • Apr 2023
                      • 6
                      Doesn't look like I can edit the above post... I finally spent enough time reading around to realize that the main BIOS chip above was not what I needed. I looked under the processor fan shroud and found a Winbond 16MB BIOS 8 pin chip, that one worked with my EZP2019+ and RCUnlocker.
                      I did run into a problem where I had to run the unlocker as admin, so I had to use command line to make it work. In an admin level CMD, navigate to the where unlocker is stored and also where you copied your .bin, and type:
                      rcunlocker.exe yourBIOS.bin
                      Replace yourBIOS.bin with the file name you used and it should work.
                      • bilal046
                        • Aug 2017
                        • 23
                        • Türkiye
                        #31
                        hp prodesk 600 g6 desktop mını pc password
                        sn:8cc20801z4
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11225
                          • Viet Nam
                          #32
                          Re: hp prodesk 600 g6 desktop mını pc password
                          Originally posted by bilal046
                          clear my bios pass please
                          sn:8cc20801z4
                          11111111
                          • badmac02
                            • Jan 2024
                            • France
                            #33
                            I'm french, sorry for my english
                            have you managed to initialize the password of your prodesk 600 g6 mini?
                            If so, how do you do it?
                            Because I have the same problem.
                            Thanks in advance​
                            • highping0r
                              • Nov 2019
                              • 15
                              Hey guys,
                              can someone give me clean Bios and EC file? I unlocked password on EC with RCUnlocker but got the "HP Endpoint Security Controller Problem" Error after. Reset didn´t work and i tried BIOS update with HP software. now im stuck in Update loop and error still exists.
                              Attached is the EC file i read with password.
                              SN: 8CC2230687
                              I also did a second device that worked fine at first attempt.
                              Thank you
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11225
                                • Viet Nam
                                #35
                                Originally posted by highping0r
                                Hey guys,
                                SN: 8CC2230687
                                Thank you
                                Upload bios file .
                                • highping0r
                                  • Nov 2019
                                  • 15
                                  Originally posted by hoaca388
                                  Upload bios file .
                                  Both files that are flashed right now. There might be a mismatch. If you need i can also upload the two chips from the other device that workes. maybe just change the SN and so there?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11225
                                    • Viet Nam
                                    #37
                                    HP ProDesk 600 G6 Desktop Mini PC (5S1F0EC)
                                    • highping0r
                                      • Nov 2019
                                      • 15
                                      worked! thanks a lot
                                      • Macdonald
                                        • Mar 2021
                                        • 23
                                        • Zimbabwe
                                        #39
                                        hie i have an Hp ProDesk 600 G6 10th gen i need to install windows 7 but the bios does not have legacy support how can i get the bios that support legacy
                                        anyone who can help i need a bios that support legacy support
                                        serial number
                                        ICZ1240997
                                        This is my attached bin file
                                        • angel148644
                                          • Dec 2013
                                          • 13
                                          • Guatemala
                                          #40
                                          Hi, good afternon, Can someone clean ME this bios. Its from HP Prodesk 600 G6 Desktop Mini, DAF93MB36B0 REV B. Thanks, I tried it with "CSME System Tools v14.0.20" software but didnt work. Thanks for your time.
