Help HP PRODESK 600 g6 mini bios file
  • hoaca388
    Badcaps
    • Jan 2022
    • 12316
    #61
    Originally posted by Tre Bor
    Hello Hoaca388,
    I also have a 600 g6 mini pc with "manucafturing program mode" mpm error on startup if i press space i can boot into windows. with the bcu tool i get the config.txt but there is no feature byte data in the file. i also tried with powershell and check_feature_byte script but no luck.
    what can i do the fix the mpm error message on boot ?
    Kind Regards
    Robert
    Serial number ?
    • Tre Bor
      • Feb 2025
      • 5
      • Nederland
      #62
      the serial nr is 2UA2341QHS
      Robert
      • hoaca388
        Badcaps
        • Jan 2022
        • 12316
        #63
        Robert
        Serial Number : 2UA2341QHS
        Product Number : 3A3F3UC
        Description : HP ProDesk 600 G6 DM​
        Buil ID : 20WWQ6GT6**#SABA#DABA
        Fearture byte : 3E476J6S6b7B7H7M7Q7T7W7mapaqaubhcAdpdqfPhKjhk8mEnVpqqp.an
        • menes92
          • Aug 2019
          • 8
          • Turk
          #64
          HP prodesk 600 g6 mini bios has a password. Can you remove the password? I have attached 16 and 32 mb files
          SERIAL : MXL2313CWJ
          • hoaca388
            Badcaps
            • Jan 2022
            • 12316
            #65
            SERIAL : MXL2313CWJ
            Unlocked
            • Potato Farmer
              • Jan 2025
              • 5
              • United States of America
              #66
              Ive got another locked HP ProDesk 600 G6 SFF
              Can someone help me edit the .bin files so the BIOS password is removed?
              I think I figured out how to modify the BIOS, but the ROM file seems to have many sections that need blanking out and im a little lost, These are the files I have extracted.
              Serial Number is MXL3182MCB
              Thanks!
              • hoaca388
                Badcaps
                • Jan 2022
                • 12316
                #67
                Thanks!
                16 MB file is corrupted
                • Potato Farmer
                  • Jan 2025
                  • 5
                  #68
                  Oops, I tried reading the chip again, I think its correct now.
                  • laytons
                    • Jul 2024
                    #69
                    Hello, i was wondering if someone would be able to unlock my Bios file. Its from a HP Prodesk 600 G6
                    Serial Number: MXL2082Z4Q
                    I'm also wondering what tools are being used for this, so i wouldn't have to bother anyone next time.
                    Thank You & Appreciate it
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12316
                      #70
                      Find RCunlocker.
                      • laytons
                        • Jul 2024
                        #71
                        Originally posted by hoaca388
                        Find RCunlocker.
                        I've used RCunlocker a few times in past, it worked on some but not on others. When it would work, it would show me all the details of the PC on the RCunlocker unlocked screen. I ran this bin through it , it didn't give me any of those details.Also it didn't ask for a serial number. I was worried to flash it, because in the past when it didn't give me those details, after I flashed it the bios was corrupted and I never got it working again, even after flashing the original bios bin. Maybe in those cases it was my soldering that was the issue, but I wanted to ask a professional before I went ahead with flashing the bin from RCunlocker.
                        If your able to get that bios file unlocked I could send you something for the help.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12316
                          #72
                          Tôi đã sử dụng RCunlocker một vài lần trong quá khứ, nó hoạt động trên một số máy nhưng không hoạt động trên một số máy khác. Khi nó hoạt động, nó sẽ hiển thị cho tôi tất cả các chi tiết của PC trên màn hình mở khóa RCunlocker. Tôi đã chạy thùng này qua nó, nó không cung cấp cho tôi bất kỳ chi tiết nào trong số đó. Nó cũng không yêu cầu số sê-ri. Tôi đã lo lắng khi flash nó, bởi vì trước đây khi nó không cung cấp cho tôi những chi tiết đó, sau khi tôi flash nó, bios bị hỏng và tôi không bao giờ làm cho nó hoạt động trở lại, ngay cả sau khi flash thùng bios gốc. Có thể trong những trường hợp đó, vấn đề là do mối hàn của tôi, nhưng tôi muốn hỏi một chuyên gia trước khi tôi tiếp tục flash thùng từ RCunlocker.
                          Nếu bạn có thể mở khóa tệp bios đó, tôi có thể gửi cho bạn một số thứ để được trợ giúp.
                          Yes, because the file you posted is an EC file, not the main bios.​
                          • laytons
                            • Jul 2024
                            #73
                            Vâng, vì tệp bạn đăng là tệp EC, không phải bios chính.
                            Thank You, I thought that was the main chip. I'm new to this. I tried to wire up a SOIC 16 clip, but didn't have any luck getting a good connection. I'll have to order one. I did find a bypass to reset the bios after some Google searching. If anyone has this model and is interested I'll post it below. It worked for me. Thank You for your help though.
                            Remove the BIOS password from an HP Elite 800 G6 without EPROM programer
                            • davanros
                              • Dec 2020
                              • Italia
                              #74
                              Hi everyone, these are my first experiences here, and there is a lot of material. I have an HP Prodesk 600 G6 SFF of which I forgot the BIOS password, I unsoldered it, I bought a T48, I read and saved the .bin file that I attach, the serial is CZC103BTXW, is there anyone who can unlock it or explain to me how to do it? Do I also have to read the EC? Could it be that the EC is a MX25L12872F chip?
                              I tried to use RCUnlocker on the attached file, but it says: "Wrong chip". The Bios chip I have is that one, and it is 32Mb, what should I do?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12316
                                #75
                                HP ProDesk 600 G6 Small Form Factor PC
                                Serial_CZC103BTXW
                                Product_9AW71AV
                                Build Id_20WWP6BT601#SABZ#DABZ
                                Fearture byte_3E3X476J6S6b7B7H7M7Q7T7W7maBapaqaubhcAdUdpdqfAfPhKjhk8mE.mn
                                • davanros
                                  • Dec 2020
                                  • Italia
                                  #76
                                  Serial_CZC103BTXW
                                  Product_9AW71AV
                                  Thak you, can I try file attached?
