GA-H81M-S1 rev 2.1 bios needed
  • soumya199929
    • Apr 2022
    • 65
    • India
    # All bios editor and collector if anyone has GA-H81M-S1 rev 2.1 bios then please upload it here i need it sending also the corrupt file.
    #smdflea.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: GA-H81M-S1 rev 2.1 bios needed
    You can get the rev 2.1 bios from Gigabyte support:
    https://www.gigabyte.com/Motherboard...upport-dl-bios
    • soumya199929
      • Apr 2022
      • 65
      • India
      Actually i have tried all 3 bios file from the official site and they are not working properly .
      the debug card is showing cod 15 and then restarting but to my experience and diagnosis it is the corrupt bios so i request if anyone have working bios please post it.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        The file you posted is 4MB in length: 4194304 bytes / 1024 / 1024 = 4MB
        The length on Gigabyte website is: 8388608 bytes / 1024 / 1024 = 8MB
        Please check what BIOS chip is installed on your board and verify your BIOS chip writer settings.
        • soumya199929
          • Apr 2022
          • 65
          • India
          All 3 files in official website are 4 mb and so is my chip is 25l32... so it is also 4 mb .
          there is no 8 mb but if you have 8mb bios for this mobo send it i will try with another chip of 25q64... Looking forward for help as Hansson's suggestion.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            The file you posted has a filename of GA-H61M-S1 REV 2.1
            The title of your thread is GA-H81M-S1 REV 2.1
            Please check your actual board model.
            The length I posted above was for board revision 1.0 by mistake, all others are 4MB as you say.
            • soumya199929
              • Apr 2022
              • 65
              • India
              sorry my mistake the file name was mis typed it is gah81m s1 rev 2.1 sorry for inconvenience.
              Tell me how can i change it.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                If flashing the BIOS does not help then probably the problem is somewhere else.
                Or the problem is a hardware fault of the EEPROM, did you try to read it back after programming it and make sure it is the same?
                • soumya199929
                  • Apr 2022
                  • 65
                  • India
                  It is very common for this type of board for bios corruption or internal byte of chip and actually from experience i got it working if i forcefully keep the psu on at code 15 then after few sec release it and i also boot into windows so my theory regarding it is the bios chip is internally damaged in this process some bits changed because of which i provided that file if anyone can repair it
