biostar j1800nh2 ver:6.0 bios request
  • umit
    • Dec 2015
    • 61
    • türkiye
    please help me bios needed original bios i added here
    • 21853
    Re: biostar j1800nh2 ver:6.0 bios request
    Did you look for the bios at the support site https://www.biostar.com.tw/app/es/eo...D=727#download
    Rename from .BSS to .bin if your programmer doesn`t recognise the file extension
    • umit
      • Dec 2015
      • 61
      • türkiye
      Hello, I downloaded it from the site, the content is very different from the original, so it does not work.
        • 21853
        Its the right bios for the motherboard.It will look different as the TXE firmware hasn`t been initialised until its booted (it will only change if the board is working with no other faults) ,and the NVRAM is not populated until its booted.
        Make another backup and compare with the unbooted virgin bios,if both files are still the same the motherboard isn`t posting,the bios isn`t being read or written to.
        • umit
          • Dec 2015
          • 61
          • türkiye
          can you edit original bios
            • 21853
            what is there to edit ? ,if the TXE firmware is cleaned and NVRAM cleared it will be the same as the virgin bios,assuming theres no other corruption in your backup,it only takes a few bytes to be bad and you can`t tell just by looking. If the virgin bios hasn`t worked the problem is 100% somewhere else
            • umit
              • Dec 2015
              • 61
              • türkiye
              :Niye:
              üşünme:
              • umit
                • Dec 2015
                • 61
                • türkiye
                I wrote the cap file that I downloaded, the device did not work, but there is no image in the original bios.
                  • 21853
                  Is your programmer an EZP**** ,i think your programmer is trying to remove a CAP header that isn`t there. It isn`t a cap file,just rename it from .BSS to .BIN before programming
                    • 21853
                    here.
                    • umit
                      • Dec 2015
                      • 61
                      • türkiye
                      here.
                      Hello, I wrote bios but it didn't work. I added a photo, I showed it in the related volt photo, there is no error, but it did not work
                        • 21853
                        start a new thread here if you want more help https://www.badcaps.net/forum/forumdisplay.php?f=14 .The bios is ok,assuming your programmer wrote it ok and you have verified it.
                        • umit
                          • Dec 2015
                          • 61
                          • türkiye
                          biostar J1800NH2 VER:6.0
                          Hello, the motherboard does not start, I have shown the volts in the photo, I really need a working bios, please help, I backed up the original bios.
                            • 21853
                            Re: biostar J1800NH2 VER:6.0
                            Desktop PC bios requests and schematic requests ONLY go here: https://www.badcaps.net/forum/forumdisplay.php?f=15
                            Desktop PC repairs (Not bios requests or schematic requests) go here: https://www.badcaps.net/forum/forumdisplay.php?f=14
                            The two parts of the forum are seperate. There is no need to post the same bios request again, i have posted a fully working bios for you.
                            When you write the bios select the chip manually,do not use auto-detect, the chip part number is etched on top,choose it from the support list. When you have written it it should automatically verify. Read it back again from the chip to make sure it has actually written to it,and compare it with the file i posted using a hex editors file-compare function. I use HxD hex editor,its free and there is a turkish language version.Just open both bios with it then select Analysis -> Data Comparison -> Compare .If they are the same then the bios has been written correctly and the problem is somewhere else.
                            https://mh-nexus.de/en/hxd/
                            • mjavicop
                              • May 2022
                              • 6
                              • quito
                              bios J1800nh2 ver: 6
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
                              • David Gee
                                Bios Request HP 17-CN0023DX
                                by David Gee
                                I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
                                I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
                                05-03-2025, 09:58 AM
                              • greelidd
                                K6604J Vivobook RTX 4070 BIOS Dump Request
                                by greelidd
                                Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                09-01-2025, 06:14 PM
                              • TacticalFahrrad
                                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                by TacticalFahrrad
                                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                06-30-2025, 04:09 AM
