[Request] Asus A320M-k updated BIOS Dump
  • abel2b
    replied
    Re: [Request] Asus A320M-k updated BIOS Dump
    ??? nothing
  • abel2b
    replied
  • abel2b
    replied
    Originally posted by SMDFlea
    Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. (LENGTH 800)
    Well I reflashed everything as instructed and no luck!
    No video, post, beeep nothing just amber LED and CPU come on...
  • abel2b
    replied
    There is a difference between the 6402 i extracted and your file, theres a serial number in yours,i don`t know why,but it should be ok,take the cmos battery out and flash it .
    OOH yeah the 6402 *.bin file, well I added DMI data from backup with FD44Editor_0.9.2 that is why serial number, UUID is there
    I´ll try in just a minute
    replied
    Originally posted by abel2b
    Not Quite sure what you mean by (LENGTH 800) but I believe so....
    Just in case I will attach Asus website latest CAP file and extracted Bin by Uefitool please verify ... THX
  • abel2b
    replied
    Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. UEFITool has removed the CAP header ok 0 - 7FF (LENGTH 800)
    replied
  • abel2b
    replied
    According to Asus CPU support for this board, a Ryzen 5 4600G is supported or validated since BIOS Ver. 5862 so I downloaded latest version 6402…
    I connected my CH341A (Green) programmer with 1.8V adapter to the board.
    I identified pins as follows…
    Then I fired up NeoProgrammer V2.2.0.10, identified chip as Gigadevice GD25LQ128C [1.8V] and read data successfully and saved backup…
    OK so then I opened the updated BIOS CAP with UEFITool NE Alpha 59 , then - right-click onto the listed “AMI Aptio capsule”, choose the option “Extract body…” and save it as *.ROM file. (File size 16,384 KB)
    I then erased and verified blank chip with NeoProgrammer successfuly, then opened new *.ROM file and flashed, Successfully… I removed programmer cables, installed CPU and powered up… :frowning_face:
    It didn´t POST, boot or display anything (Fans running)
    I also have tried with no luck, manually editing *.CAP file with HxD and removing first 2048 bytes and saving as *.ROM, I also tried Asus CAP to Bin Tool to create *.ROM file, I tried flashing with CH341 programmer original soft, with AsProgrammer I even flashed with Flashrom for windows, in all cases no errors where displayed… yet Mother Board refuses to POST…
    SOOO! What am I doing wrong!
    what is the proper way to do it…
    Any help would be greatly appreciated…
    P.S please excuse my English, it is not my native tongue…
  • abel2b
    replied
    Originally posted by hoaca388
    post your original corrupt bios here.
  • hoaca388
    replied
    Post your original corrupt bios here.
  • abel2b
    started a topic [Request] Asus A320M-k updated BIOS Dump
    Hello, anyone have BIOS Dump (ROM/BIN) for Asus A320M-K, dump has to be version 5862 or higher, so I can use with Ryzen 5 4600G CPU.
    I do not have a spare older generation compatible CPU to boot and update via Bios EZFlash Utiliy...
    Also I will be flashing via CH341A programmer with either (AsProgrammer, NeoProgrammer, Flashrom)
    I´ve tried the usual extraction of file with UEFITool --->
    Open the *.CAP file, do a right-click onto the listed "AMI Aptio capsule", choose the option "Extract body..." and save it as *.ROM file. from latest BIOS *.CAP file and later flashed with no luck... board will not POST anything
  • Sebastian Codrean
    BIOS file for ASUS F542UN laptop
    by Sebastian Codrean
    Hello to all of you! I need help with a BIOS file.
    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
    02-20-2025, 10:25 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • Shamitha
    Asus X540UA i3 8 generation Bios Dump / Bin File
    by Shamitha
    Can any one find me the bin file of Asus X540UA. Core i3 8 gen and on board vga. Bios are locked and need to flash new bios. Please help me !
    04-23-2024, 02:38 PM
