Hp compaq dc 5800 mac address error
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    I have recieved Hp compaq dc5800 motherboard with display fault. i did bios from hp site. Display comes out with mac address error. so there is booting problem
    SN P70130K9VXIGU0
    Borad code Cheetah Rev A
    Bios extracted from hp site Attached
    Any suggestion plzz
    • 21844
    Re: Hp compaq dc 5800 mac address error
    SN P70130K9VXIGU0
    Any suggestion plzz
    https://www.badcaps.net/forum/showpo...10&postcount=4
    • OKRPKCOMP
      • Dec 2020
      • 439
      • PAKISTAN
      Thanks sir
      But first of all, i dont have original cassing with motherboard
      So i dont have mac address mention anywhere
      Secondly, it looks to me a difficult tast to add mac address
      Especially, there is no video step by step help avail
      So i am failed. even i donwload all material about it
      But dont know, how to use it
      May i have easy and simple help to use it????
      Any video in easy way for bignersssssss
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Finally got working bios for HP COMPAQ DC5800 MICROTOWER
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • kyrios
          Flash LG PK5 DEMO - CH431A ERROR - verification error on address 00000000
          by kyrios
          Hello!
          I apoligize for my English. I need some help.
          I have an LG PK5 in demo version and trying to repair it, I found the original firmware in this forum to flash speaker to the original version.
          Without having any idea about these things, I give thanks this forum and other tutorials, I bought a CH431A programmer and I have tried to do all the steps but after reading the new firmware, in the "verification" step I get this error: verification error on address 00000000
          Could someone help me to solve it, please?
          Thank you so much
          11-30-2023, 01:06 PM
        • sushilachuthan
          APC UPS error P13
          by sushilachuthan
          one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
          the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
          The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
          We replaced the SCR with new device,, but the device is not power on as expected.
          Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
          09-26-2025, 09:00 AM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
