Bmax b2 plus
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Bmax b2 plus
    Good afternoon people,
    I have a problem on my hands that I can't find the problem.
    I have a broken bmax b2plus that gives the logo the brand and does not enter the bios or boot to the OS. I already fixed the bios and it didn't fix it. I already have the original bios from the manufacturer and flashed it and it didn't fix it. Now I was trying to replace the bios chip with a new one but it is not working. What happens is that the original chip of the machine is the W25Q64FWSIQ and the one I am replacing is the W25Q64FWSIG, but with the W25Q64FWSIG the machine does not start nor the image (with the same file read from the W25Q64FWSIQ).
    I've been looking at the datasheet and both chips are the same. Can anyone tell me why this new chip doesn't work on this machine?
    I've already recorded both chips with the RT809H, TL866A, CH341A and with SVOD3 and it doesn't solve the problem.
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Re: Bmax b2 plus
    do you have communication on the data lines from the bios chip?
    works with an oscilloscope if you don't have one you can also use an LED
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      Re: Bmax b2 plus
      I don't have the equipment right now. But how do I test with a led?
      What pins of the chip do I need to test on? On pin 2 and 5?
      • piernov
        • Jan 2016
        • 4435
        • France
        Re: Bmax b2 plus
        W25q64fwssig: Qe=0
        w25q64fwssiq: Qe=1
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          Re: Bmax b2 plus
          Originally posted by piernov
          W25q64fwssig: Qe=0
          w25q64fwssiq: Qe=1
          @Piernov how can I get this chip working? Just change Qe to 0 or 1 on the new chip? Or do I have to buy an exact same chip?
          • 18664520780
            • Aug 2023
            • 中国
            Re: Bmax b2 plus
            HI,
            Anyone have a bios dump from Bmax b2 plus?
            thanks
            • Sa33nS
              • Jan 2025
              • 7
              • Россия
              Originally posted by 18664520780
              Re: Bmax b2 plus
              HI,
              thanks
              Hi!
              If you haven't found it yet, try it. -
              Bmax b2 plus bios - Badcaps
                ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-12-2024, 03:28 PM
              • CG2
                Janome DC3050 Sewing Machine Pedal Resistance
                by CG2
                OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                04-14-2023, 07:53 AM
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
              • unimatrix93
                How to stabilize AC voltage to CNC machine
                by unimatrix93
                Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                I have a CNC machine wired to 3-phase 230V AC.
                It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                I contacted the electricity company but they refuse to help me solve this problem.
                So I started to look around for some DIY...
                03-17-2025, 05:52 AM
              • xdever
                820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                by xdever
                I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                01-15-2025, 08:44 PM
