Dell Optiplex 5080 micro BIOS lock
  • soti
    • Mar 2014
    • 9
    • greece
    Originally posted by jas7o
    Hi
    How you get option for change service tag ?
    I try replace in bios part with dell update one, and get maintenence mode but no option for change service tag in my old 5070 this method works for changing service tag
    Can you explain what you do "...I just removed a chunk of data from the EC region manually..." to get option change service tag ?
    This worked for me. I use HxD to edit.
    • jas7o
      • Feb 2023
      • United Kingdom
      Thank you works perfect! now I was able to change service tag on bios ver 1.1.5
      One more time big thanks
      • bakhanh
        • Aug 2019
        • 11
        • Việt Nam
        Please help Bios Password. remove pass bios... help me
          • 21869
          post the PC service tag - https://www.badcaps.net/forum/troubl...before-posting
          • bakhanh
            • Aug 2019
            • 11
            • Việt Nam
            servicetag: 9Y2Z5C3-8FC8
            thankyou​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12328
              #26
              thankyou​
              Unlocked
              • bakhanh
                • Aug 2019
                • 11
                • Việt Nam
                #27
                Originally posted by hoaca388
                Unlocked
                cảm ơn bạn. máy hoạt động hoàn hảo...
                  • 21869
                  Post in ENGLISH !!!!!!!!!!!!!!!!!!
                  • macintoxxx
                    • Feb 2025
                    • 3
                    • Netherlands
                    #29
                    I bought a second hand Dell Optiplex 5080 micro with a password in the BIOS. Now I understand that I need to make a dump of the BIOS. How do I do that?​
                    • macintoxxx
                      • Feb 2025
                      • 3
                      • Netherlands
                      #30
                      Servicetag 2YHHB93
                      • nesredin
                        • Feb 2018
                        • 39
                        • ethiopia
                        #31
                        THIS file is 3080 10th gen Small Form Factor
                        ​ its work perfect i only need to change model number to 5080 can anyone do it for me
                        ST J6Y6N83
                        ONLY MODEL NUMBER CHANGE
                        • nesredin
                          • Feb 2018
                          • 39
                          • ethiopia
                          #32
                          Unlocked
                          I recently upgraded my Optiplex 5080 SFF from i5-10 to i7-10 th and after that, on every boot I received and error showing this message: Alert! VR Heat sink not detected.
                          how to bypass this error without installing this vr heatsink? i update the bios but same problem
                            • 21869
                            There is no problem with the bios. Similar model here - https://www.dell.com/community/en/co...e27cad9?page=2 ,bridging a wire between the 2 screw holes will work, but it is still recommended to install the heatsink.
                            • nesredin
                              • Feb 2018
                              • 39
                              • ethiopia
                              #34
                              thank you it works with bridging a wire between the 2 screw holes
                              • jj.ww
                                • Jan 2023
                                • 30
                                Hello could I get help removing Absolute From File Please
                                ST:FQPTMF3
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12328
                                  #36
                                  ST:FQPTMF3
                                  OptiPlex 5080 Micro
                                  Service Tag: FQPTMF3
                                  • jj.ww
                                    • Jan 2023
                                    • 30
                                    hello hoaca388. Thank You.
                                    The first file worked.
                                    • Bruhdini
                                      • Jul 2025
                                      • United Kingdom
                                      #38
                                      Hi there, I'm trying to get into homelabbing and I had a dell optiplex 5080 lying around but it's got a bios password preventing me to load a new OS on it. If I post the service number can somebody help me with the bios password or do I need to upload some kind of zip aswell since I've seen other people do that?
                                      Here's the service number anyways: 5RTB4F3-8FC8
                                      Thanks for the help!
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12328
                                        #39
                                        Post the original bios file.
                                        • Bruhdini
                                          • Jul 2025
                                          • United Kingdom
                                          #40
                                          Is a .bin file from Dell that is the same version as the bios on my PC enough or do I need to get the actual file off my chip?
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
                                            DELL OptiPlex 5080 OptiPlex 5000 i3-10100 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 5080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5080 boardview and OptiPlex 5080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL OptiPlex 5080 OptiPlex 5000 i5-10500T Specification for Upgrade or Repair
                                            09-12-2024, 03:36 PM
