Need Msı AE2281G bios dump
  • bilen
    • Aug 2014
    • 632
    • istanbul
    orginal dump deleted. motherboard code : MS-AA711 REV 1.1
    Thank you
  • peste
    • 12627
    • ROMANIA
    Re: Need Msı AE2281G bios dump
    Thank you
    https://www.msi.com/Business-Product...2281#down-bios
    • bilen
      • Aug 2014
      • 632
      • istanbul
      my model : AE2281G does not fit
      • lotas
        • Jan 2016
        • 4557
        • Russia
        Try
          • 20665
          here
          • bilen
            • Aug 2014
            • 632
            • istanbul
            Originally posted by lotas
            try
            not workİng
            • bilen
              • Aug 2014
              • 632
              • istanbul
              Originally posted by SMDFlea
              here
              not working
                • 20665
                not working
                Then the problem is somewhere else .
                • bilen
                  • Aug 2014
                  • 632
                  • istanbul
                  There was no problem with the device. I accidentally deleted my bios backup
                    • 20665
                    not workİng
                    • bilen
                      • Aug 2014
                      • 632
                      • istanbul
                      not working. these bios are not compatible with my card.
                      get a picture of your card
                      • nassimhamdi
                        • Feb 2016
                        • 149
                        • algeria
                        me too
                          • 20665
                          Originally posted by nassimhamdi
                          me too
                          me too ? ,whats the problem ? .If you have a backup post it
                          https://www.badcaps.net/forum/showthread.php?t=103569
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • grimacelord
                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                            by grimacelord
                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                            Motherboard model number: DA0PAMB46A1 REV: A
                            Secondary motherboard model number: 0PAB
                            SKU: 685K4UA
                            Serial number is: 5CD3223BJP
                            Recently reflashed this laptop with latest BIOS and once...
                            05-07-2024, 08:06 AM
                          • DynaxSC
                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                            by DynaxSC
                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                            11-06-2022, 05:22 PM
                          • TacticalFahrrad
                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                            by TacticalFahrrad
                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                            06-30-2025, 04:09 AM
