HP Pavillon27 All-In-One , completely off.
  • amennone
    • Feb 2015
    • 63
    • italy
    Model No. 27-r006nl
    Product No. 2XC73EA#ABZ
    Main board DA0N73MB6D0 REV
    Spi 25q64
    No light blinks, the fan is not spinning, on the SPI 25Q64F, no voltage.
    Voltage presence LED on.
    Power supply O.K.
    I disconnected the battery from the bios in an attempt to reset, nothing has changed.
    Looking for diagram Main board DA0N73MB6D0 REV: D.
    Thanks and good job
  • daniel5455
    • Sep 2017
    • 16
    Re: HP Pavillon27 All-In-One , completely off.
    Did you ever find the issue? I have the same board and same issue.
    • falcontech
      Denon Mc6000 channel 1 completely non-functional
      by falcontech
      Hello
      I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
      09-04-2025, 09:03 AM
    • max-power
      Dell E6540 laptop completely dead after dssasembly
      by max-power
      Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
      that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
      After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
      03-24-2025, 08:49 AM
    • cristy72
      Orion CLB22RT500d need good dump 25q64
      by cristy72
      Heloo. I need good dump for Orion CLB22RT500d . My dump is corrupt , continous restart .
      Mainboard is T.SIS231.31 , with 25q64 eeprom .
      Display : T215B1-P01-L05
      I atached here corrupted dump .
      Thanks in advance !...
      11-18-2024, 11:19 AM
    • fiveseventy
      RX570 dies completely, then recovers.
      by fiveseventy
      Hello all,
      I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
      The card was bought used maybe 5 years ago and has worked without issue until recently.
      I have no reason to believe it has been worked on or physically damaged.
      For periods of time it will be 100% perfect.
      Perfect temperatures, no glitches or artefacts, solid FPS.
      I can game, run benchmarks, do whatever without any problem.
      I can reboot the machine as many times as I like and nothing changes
      however, most times...
      06-22-2024, 05:29 AM
    • pavski
      Completely dead MSI z490 tomahawk
      by pavski
      Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
      I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
      t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
      Can you please let me know if this is indeed incorrect and what else should I look at next?
      Thanks!
      06-02-2024, 02:42 PM
