MSI B450 Mortar Max bios dump needed.
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    MSI B450 Mortar Max
    bios dump needed.
    Bios is password protected.
    can't reset with bios jumper.
  • Schorsch87
    • Feb 2013
    • 55
    Re: MSI B450 Mortar Max bios dump needed.
    Are you sure the password is stored in the bios? This will be more likely in a TPM chip or something similar.
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
    • vinaypundith
      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
      by vinaypundith
      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
      So, I'm looking for a BIOS dump for this machine - a 16MB one....
      08-03-2024, 12:32 PM
    • James Maxwell
      HP DM1-4000er Bios Dump needed
      by James Maxwell
      I badly need bios dump for HP DM1-4000er,
      Model: HP DM1-4000er
      Motherboard: DA0NM9MB6D0 REV.D
      Product: QJ490EA#ACB
      Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
      10-28-2024, 05:38 PM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
