How to Program IT8519E Externally with RT809H Programmer
  • mferna14
    • Jun 2018
    • 1029
    Hi I want to read/program the KBC file off IT8519E. Does anyone know how to do this. I have physically removed the IT8519E chip from the motherboard & I have soldered it on the addon programmable card to program on the RT809H. How will I do this? Do I have to apply 3.3 volt & ground externally from a bench power supply?? It will be great if someone can guide me, first time I will be doing this programming. Thanks
  • mferna14
    • Jun 2018
    • 1029
    Re: How to Program IT8519E Externally with RT809H Programmer
    Any Help please???
      • 21175
      Originally posted by mferna14
      Any Help please???
      I don`t own one but maybe this will help - https://www.youtube.com/watch?v=GYedPOLiUOo
      What motherboard are you working on ?
      • mferna14
        • Jun 2018
        • 1029
        Thanks for the reply. I am working on this Dell Vostro 360 AIO 2320 (PEGATRON IPPSB-SFA REV. 1.01) which does not have the keyboard connector so I have to Program the IT8519e out of the motherboard. I checked the YouTube link. He has the same Programming adapter that I have & he is doing it with the IT chip soldered on the main motherboard. As I told you, this board does not have the keyboard connector, so not much help.... Only I need to know how to do this programming externally. Thank
          • 21175
          It has an external rom according to the schematic, U9216 .Thats what needs programming. Schematic https://www.badcaps.net/forum/showthread.php?t=77292
          • mferna14
            • Jun 2018
            • 1029
            Honestly speaking I removed the I/O IT8519E from this board as I had to repair another customer unit so this was our personal DELL Vostro 360 & it was working 100% fine without any problems, only I/O was needed. This is why I ordered the I/O chip and was a bit sure that this IT8519E did not need programming, only had to solder it back to the motherboard & all would work fine. I know the BIOS chips are 100% working. Now what happens when I soldered the new IT chip, I observe it is booting into windows, but no display at all. What you think??? thanks
              • 21175
              Did you replace it with one that had the same 3 digit code. HXA CXS CXA HXS BXS AXA .That 3 digit code is important,sometimes you can repalce one with a different 3 digit code and it`ll work ok but more often than not it won`t.
              Edit: https://ascnb1.ru/forma1/viewtopic.php?f=369&t=94066 ,use google translate
              • mferna14
                • Jun 2018
                • 1029
                Yes you are right "SMDFlea".. I will check the 3 digit code before I make any assumptions. I received both HXA & CXA series. The one which is soldered on the motherboard is CXA series.. Will check & let you know. Thanks
