hi, my friends, I need Lenovo L-A780 R1.0 bios can anyone help?
request lenovo L-A780 R1.0 bios
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
Dear all, I found this forum and this is my last hope. I had a problem with BIOS update though Windows Update - it was stuck for an hour and I decided to restart. Then it bricked. The reason to update was, I had no video on my panorama display. I tried to find a BIOS on my own, but it seems that Lenovo doesn't provide a complete file, only the BIOS section. Is there any chance someone could repair it? I did a backup from the chip, attached. I also tried using another BIOS, slightly different revision. It worked and even I had a display working, but then Windows tried to update once again and it...
by HammyCheesyHello all,
I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
Type: 30BB
Model Number: S03600
S/N: MJ07N68C
Things I have tried:
1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
2. Attempted to boot with just a single CPU...-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
- Loading...
