HP 800 G1 USDT Bios problem
  • Gripen
    • Sep 2020
    • 37
    • Slovakia
    There is an HP 800 G1 USDT that has lost power during a BIOS update. Now it beeps 8 and doesn't work. I found a bios file for it. I flashed, the computer turns on but after a while the fan gets louder and then spins at 100%. I tried to copy the ME region of the old BIOS to the new one, I also tried to clean it but it didn't help. How could I solve this?
    old.bin is corrupted bios, HP Elite Desk 800 g1 _W25Q128FV.bin that I found.
  • peste
    • 13550
    • ROMANIA
    Re: HP 800 G1 USDT Bios problem
    bios extracted from the HP site update.
    • Gripen
      • Sep 2020
      • 37
      • Slovakia
      I downloaded bios from HP website, and found an L01_0278.BIN file. I flashed and the fan goes 100%. What did you send this same file?
      • podam8
        KnowledgeSeeker
        • Oct 2020
        • Polska
        had same situation, maybe this bios dump will help anyone. Working 100%, remember to copy your ME and gbe region to this bios (block 00001000 to 0057F000)
        • mkdj
          What should I do after having flashed a BIOS?
          by mkdj
          Dear all,
          I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
          Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
          09-09-2025, 09:45 AM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • traxformania
          TONGFANG "GM7TG7P" Bios Password Problem?
          by traxformania
          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
          I'm trying to reset my bios without success.
          I tried :
          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
          11-15-2023, 07:32 AM
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
