need dl-h61m-dps bios
Asrock H61M-DPS BIOS
Tags: None
Re: Asrock H61M-DPS BIOS
https://www.asrock.com/mb/Intel/H61M-DPS/index.asp#BIOS
And next time create a new thread in the proper forum area!"The one who says it cannot be done should never interrupt the one who is doing it."
by subzerilloHello.
I'm wondering how can I check and extract de dmi area from a bios backup.
I know it depends on the brand and model of the motherboard. Is there some guide that could help me understand and extract the dmi from the original bios dump to a new bios file.
The motherboard is H510M-HDV/M.2 SE
Attached is:
h510m is the dump bios
h510mhms1 is the downloaded bios from the website...-
10-09-2025, 02:23 PM -
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by gabrieljma1Hello everyone,
I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...-
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by TechMark1I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted.
I just zipped it so I could attach it....
- Loading...
