Biostar H110MHV3 Ver. 7.3 need bios dump
  • Japanac
    • Aug 2014
    • 93
    • Serbia
  • peste
    • Dec 2016
    • 12729
    • ROMANIA
    Re: Biostar H110MHV3 Ver. 7.3 need bios dump
    make a copy of the original bios, and try this.
    • Japanac
      • Aug 2014
      • 93
      • Serbia
      I need a dump with a bios that supports newer generation processors
        • 20781
        Here`s the supported CPU list and the bios downloads.What CPU are you wanting to try
        https://www.biostar.com.tw/app/en/mb...832#cpusupport
        https://www.biostar.com.tw/app/en/mb...D=832#download
        • Japanac
          • Aug 2014
          • 93
          • Serbia
          Ok,thank you
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            Today, 07:11 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
