here is the bios file that works and 100% worked on my dell inspiron one 2320 AIO with IPPSB-SFA
					Dell 2320 AIO IPPSB-SFA bios
							Channel: BIOS Requests ONLY!
			by sahamipoorhi...
 i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
 i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
 i updated to latest version and try other version but not working!
 service tag: HCQ3JW2
 i need your kind....-
			by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
 cheers
 Dell Inspiron 17 (7786) Laptop
 Service Tag: 5J0NHT2
 Bios: 1.9.0
 MOBO: RO 15 17 WHL 2GB MB / 18706-2
 Attached;
 1. My saved bios using a programmer
 2. Dells Bios updater .exe (v1.16)
 3. Dells Bios recovery file
 4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
 5. Image of ME...-
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by GadgetsFixHi everyone,
 I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
 - Model: Dell Inspiron 16 5630
- MainBoard Part Number: 4550SC01C004
- Laptop Serial No: GKH3JX3
- DP/N: 0303KM
- QUAKE N RPL UMA CS MB
- 213251-2
- TMN0H$KB
 Thanks-
- Loading...
