Request bios for HP PRODESK 600 G2 DESKTOP MINI
  • peste
    • Dec 2016
    • 12973
    • ROMANIA
    Re: Request bios for HP PRODESK 600 G2 DESKTOP MINI
    Originally posted by Mantikor
    Hi, peste! I need your help. My wife has lost bios password from her HP ProDesk 600 G2 Mini. Which tool I should use to create bios backup/return it back, HP BIOS Update and recovery? Which version? Or I need to use special program cable? Thanks in advance!
    upd: HP BIOS Update and recovery wants password for doing backup (((
    you need an SPI programmer (ch 341A, TL866), disassemble the laptop, look for the bios chip, with the programmer read the bios chip, check the content with the HxD program to be ok, make a copy and post it here and someone will delete your password, after which, rewrite the chip with the new bios and you're done.
    here is a video ... you can see more ...
    https://www.youtube.com/watch?v=DWWigscuQDY
    • Mantikor
      • Jun 2020
      • 4
      • Belarus
      Thank you for reply!
      I'm so old and lazy to solder bios chip I tried to read with special utility, dump is looks like ok. Plz check.
      • peste
        • Dec 2016
        • 12973
        • ROMANIA
        the posted bios is not ok..I don't know if due to old age or laziness ... it may be a corrupt bios, or it may have read you with errors..try to make more copies, and if they fit into the HxD it means that they are read ok, and so is the bios..posts again..if you don't feel like doing what I proposed, and the laziness is very big, try a bios from the posts in this thread that worked for others. .
        • Mantikor
          • Jun 2020
          • 4
          • Belarus
          Hi! Finally I got the CH341 (I had to follow him to the other side of the city ) programmer and read the BIOS dump. Plz check. Thanx.
          • peste
            • Dec 2016
            • 12973
            • ROMANIA
            try..
            • Mantikor
              • Jun 2020
              • 4
              • Belarus
              #26
              try..
              Thanks mate! Now is everything working good, without any password! Just like that, in plain text? Some problems with flashing using clip - after erasing, the programmer stopped seeing BIOS IC and I had to go to a friend, de-solder IC and flash it with a Mini-pro programmer. A friend suggested doing this at the very beginning
              • acd2005
                • Nov 2020
                • 3
                • Tanzania
                #27
                Can anyone assist which bios chip to use as mine is not readable at all and not able to detect in programmer. will Winbond work or does it need to be MXIC MX25L12873F as one person suggesting? the winbond i have access to is 64 and not 128 so not sure what to get.....????
                  • 21219
                  What model is your SPI programmer
                  • acd2005
                    • Nov 2020
                    • 3
                    • Tanzania
                    #29
                    Its EZP 2019
                    • acd2005
                      • Nov 2020
                      • 3
                      • Tanzania
                      #30
                      Apologies its a RT809F Serial ISP Programmer that a mate is using to do this. I assumed it was the EZP 2019 as it looked similar. Could it be this programmer cannot detect this chip?
                      • sianamcs
                        • May 2021
                        • egypt
                        #31
                        hi
                        • skyvense
                          • Jun 2021
                          • China
                          #32
                          HI, could anyone could provide an BIOS image of HP600 G2, which removes the secondary fan warning?
                          I recently replaced the CPU from G4400 to I5-6600, the system warns me every time after power on.
                          • peste
                            • Dec 2016
                            • 12973
                            • ROMANIA
                            #33
                            post the backup of the bios..the original bios ..
                            • isaman
                              • Feb 2011
                              • Bulgaria
                              #34
                              Hi Peste, would you tell me in which address of the memory the password is located
                              • peste
                                • Dec 2016
                                • 12973
                                • ROMANIA
                                #35
                                https://www.badcaps.net/forum/showthread.php?t=79956
                                • isaman
                                  • Feb 2011
                                  • Bulgaria
                                  #36
                                  Thank you Peste.��
                                  • johnaedus2
                                    • Apr 2021
                                    Hi, I have a HP prodesk 600 G2, it gives me an error message on every boot "901-Rear chassis fan failed. Press enter to continue. Its a mini desktop and doesn't have the rear chassis fan. Could you please help me resolve this issue. Thank you
                                      • 21219
                                      Post your serial number on the case and your bios backup.This type of error is sometimes caused by programming the wrong bios version.If it has the right bios then rolling back to an older version might fix it.
                                      • abdelilahocs
                                        • Nov 2018
                                        • 119
                                        • morroco
                                        #39
                                        i need bios bin for HP PRODESK 600 G2 sff pls
                                        i tested mini and mt but still doesnt work
                                        • vahidsar62
                                          • Dec 2020
                                          • 3
                                          • tehran
                                          #40
                                          HELLO evrybody i need bios (HP PRODESK 600 G2 mt) i have admin password on bios i try old methode to reset bios but no way to do it please help me
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • zean
                                            HP ProDesk 600 G5 Desktop Mini bios
                                            by zean
                                            can anybody please help me open my bios so i can adjust my settings and play the game i used to play before, it always appear to have a password i don't even know, i tried entering my desktop password but it won't open and i didn't remember that i put a password onto it
                                            Manufacturer: HP
                                            Product: 8598
                                            Serial Number: PHVUT0A8JDOIDR
                                            Version: KBC Version 08.09.20
                                            please feel free to reply onto me if there's any other information u need to know to unlock it
                                            08-31-2024, 10:18 AM
                                          • SystemFuchs
                                            Need help with BIOS Admin PW for HP ProDesk 405 G6 Desktop Mini PC
                                            by SystemFuchs
                                            Hi there,
                                            I need your help, dumped the BIOS with CH431a controller, but the usual tools are not working because it is a 32MB Bios file.
                                            Serial: 8CC13458H1...
                                            01-28-2025, 02:54 AM
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                          • eric2022
                                            HP ProDesk 405 G6 Desktop mini bios
                                            by eric2022
                                            HELP CLEAN ME
                                            HP ProDesk 405 G6 DESKTOP MINI PC
                                            SNL 8CC152147M
                                            daf92mb26b0
                                            06-18-2024, 02:42 AM
