Problem with Asrock H170M Pro4
  • Aliencomputres
    • Aug 2019
    • 220
    • România
    Have two of this mainboard brand new.Both power up but no screen.
    I ll put two cpu,two psu and many bars of ram.If i take off the buzzer no beep.
    Try to write bios chip with first or last bios on the Asrock site,my programmer EZP 2019 said file its too long .
    https://www.asrock.com/mb/Intel/H170...ex.ro.asp#BIOS
    Original bios bin it was on mainboard chip saved.
    Thx.
    • 22130
    Re: Problem with Asrock H170M Pro4
    The instantflash bios version is the correct size,after extracting it from the zip. Its a problem with your programmer or programmer settings. Try also renaming the bios to .bin , .rom .Post your bios backup here .
    • Aliencomputres
      • Aug 2019
      • 220
      • România
      rev 1.50 from Asrock site is 16 mb and the original bios from mainboard is 8 mb.
      • Aliencomputres
        • Aug 2019
        • 220
        • România
        Same topic here
        https://forum.laboneinside.com/viewtopic.php?f=9&t=6974
        • Aliencomputres
          • Aug 2019
          • 220
          • România
          i cant upload the original bios bin.
          Try to upload but nothing happens.Why?
            • 22130
            check the advanced button - Manage Attatchments, then post a zip or rar.
            • Aliencomputres
              • Aug 2019
              • 220
              • România
              ok.
              Thank you very much.
              In attach is the bios i ll have on the both motherboard.
                • 22130
                The bios is corrupt,its from an MSI Z97 Gaming 5. Anyway, its the wrong bios,wrong size bios chip .
                • Aliencomputres
                  • Aug 2019
                  • 220
                  • România
                  Ok.
                  The bios chip on the mb is 25L12873FPI.
                    • 22130
                    The 25L12873F is a 128MB chip,divide it by 8 ,we get 16 so the bios chip is the right size. According to the datasheet though it has permanent quad enable set QE=1 ,and quad i/o isn`t set in the bios,you can check it if you open the bios with intel flash image toolkit.TheVSSC table in the bios has a winbond W25Q128FV ,the PDIP part number are: W25Q128FVAIG,W25Q128FVAIP,W25Q128FVAIQ,W25Q128FVAIF . The W25Q128FV isn`t in the EZP support list,you might be able to cross reference it with something else that is,then disable the ID check and program it as that, or use a different programmer .
                    https://www.hklrf.com/24download/img/EZP2019-List.txt
                      • 22130
                      buy the W25Q128FVAIG
                      • Aliencomputres
                        • Aug 2019
                        • 220
                        • România
                        One of them powering up,and have bios post.
                        Try later another one.
                        Inscription on the bios chip on the mb is 25L12873FPI
                        Programmer identified the chip like KH25L12835F
                        Flash BIOS with ch341a programmer black and the bios ver 7.20 on official site.-with the original bios chip on the motherboard.
                        Well, thanks a lot, SMDFlea.
                        • Aliencomputres
                          • Aug 2019
                          • 220
                          • România
                          And the second mb its been resurrected.
                          Thx again SMDFlea.
                            • 22130
                            You`re welcome .
                            • cr4zychriss
                              by cr4zychriss
                              • Rebrand: PC Specialist
                              11-14-2025, 04:04 PM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • AquaMan Ua
                              Problem with PANASONIC CF53 laptop after changing BIOS settings
                              by AquaMan Ua
                              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                              05-17-2025, 09:40 AM
                            • traxformania
                              TONGFANG "GM7TG7P" Bios Password Problem?
                              by traxformania
                              I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                              But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                              I'm trying to reset my bios without success.
                              I tried :
                              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                              11-15-2023, 07:32 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
