ASRock > B75 Pro3-bios bin
  • Aliencomputres
    • Aug 2019
    • 218
    • România
    Hi all !
    Need ASRock > B75 Pro3-bios bin please!
    Thx in advance!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: ASRock > B75 Pro3-bios bin
    why not directly for their website
    Im Back... sort of...
    • Aliencomputres
      • Aug 2019
      • 218
      • România
      Problem solved.
      Thx.
      • atzimpourdakas
        • Jul 2020
        • Greece
        Need ASRock fm2a78m pro4+ bin please
          • 22035
          see the thread title - ASRock > B75 Pro3-bios bin . start your own thread .
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • pkslowk
            Debug Card Error Code and Solution
            by pkslowk
            Sr. Motherboard Debug Error Code Solution
            1 Intel 845 E9 Bios Related Problem
            2 Intel 845 D4 CPU Socket Related problem
            3 Intel 845 37 Bios Related Problem
            4 Intel 845 7C Bios Related Problem
            5 Intel 945GCPE 34 Bios Related Problem
            6 Gigabyte 845 2 Ram Related Problem
            7 IBM Server A6 A7 Ram Mismatch Problem
            8 Asus 845 29 CPU Related Problem
            9 Lenovo I946 97 C-Mos Jumper related
            10 Gigabyte 845 A0 CPU Related Problem
            11 Asrock G31M-VS D7 Bios Related Problem
            12 Compaq 845 BD-70G B0 CPU Socket Related problem...
            01-28-2021, 12:51 PM
          • Stunt
            Hp Laptop Stuck on Hp protected by hp sure start screen
            by Stunt
            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
            screen that's it and stuck there. I left it until the following day and i still...
            09-02-2025, 01:51 PM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • letmealone
            Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
            by letmealone
            I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
            09-16-2024, 10:03 AM
