Bios Dump Acer Allinone Z5771
  • qonma
    Kuli Solder
    • Jun 2017
    • 184
    • INDONESIA
    HELLO...
    NEED BIOS ACER ALL IN ONE Z5771
    CODE MAINBOARD : IPISB-AG REV 1.04 SIZE 8 MB
    THANKS
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Bios Dump Acer Allinone Z5771
    Acer has only bios update for this model-so old bios is needed to build new bios. Post your old bios here. Someone will try to fix it.
    • qonma
      Kuli Solder
      • Jun 2017
      • 184
      • INDONESIA
      this file original bios
      acer has only bios update for this model-so old bios is needed to build new bios. Post your old bios here. Someone will try to fix it.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        @Gonma, I'm bit confused. I think this mb should have 8MB as main bios and 512K as EC bios whereas your posted bios is 4mb. Can you recheck and confirm the size of your bios eeprom on mb?
        • String2016
          • Nov 2015
          • 2238
          • philippines
          here i share main and ec try this and report back
          • qonma
            Kuli Solder
            • Jun 2017
            • 184
            • INDONESIA
            diferent bios, we have REV 1.04
            • qonma
              Kuli Solder
              • Jun 2017
              • 184
              • INDONESIA
              am sorry , have 3 ic bios, am stil check, which one main bios
              • qonma
                Kuli Solder
                • Jun 2017
                • 184
                • INDONESIA
                this position the ic bios and code of mainboard
                • qonma
                  Kuli Solder
                  • Jun 2017
                  • 184
                  • INDONESIA
                  meybe have the schematic, we want to cek the voltage
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    here try and report back 1.04version
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      the one with the letter 64 in the name of the chip should be your main bios.
                      • qonma
                        Kuli Solder
                        • Jun 2017
                        • 184
                        • INDONESIA
                        thankyu master
                        • qonma
                          Kuli Solder
                          • Jun 2017
                          • 184
                          • INDONESIA
                          thankyou very much master
                          • alexm22
                            • Sep 2019
                            • 37
                            • argentina
                            gracias thanks
                            • burakmvl
                              • Dec 2017
                              • 18
                              • turkey
                              thank you so much
                              • Monkfish
                                • May 2021
                                • 5
                                • United Kingdom
                                On my 1.04 board the BIOS chip is a Winbond 25Q32BVSIG
                                • Monkfish
                                  • May 2021
                                  • 5
                                  • United Kingdom
                                  Upgrade from Sandy to Ivy
                                  Hi everyone, maybe you can help me? I'm trying to upgrade my Aunt's old Acer AIO Aspire Z5771 system by installing an SSD, 8GB RAM and a clean install of Win 10. I would also like to upgrade her old Pentium G620 sandy bridge CPU to a Core i5-3470s ivy bridge which I have already purchased. The technical manual for her system says the system should support an i7-3770s, i5-3330s and i3-2400s, so I assumed it should support the Core i5-3470s (provided the motherboard can support the BIOS file size).
                                  Unfortunately, when I install the CPU and power on, I just get a blank screen and 4 beeps, which I believe means the current BIOS doesn't support ivy bridge CPUs. There are BIOSes on the ACER webpage that do support ivy bridge, but I can't get any of them to flash. I just get a message saying the BIOS size (3MB bin file) doesn't match the current BIOS size (2MB bin file). I have made sure the files are fully unzipped, so that isn't the problem. The BIOS Chip is a 4MB Winbond 25Q32BVSIG so I thought that would be large enough. The motherboard version is 1.04. I have seen board versions 1.02 and 1.06 online, so mine is in the middle.
                                  I'm not sure if the bios in the following thread will help me?
                                  Thread
                                  I have included all relevant information below (including a link to the BIOS files available for this motherboard).
                                  System: Acer AIO Aspire Z5771, manufactured 23 Sept 2011 (Part Number: DO.SL1AA.001)
                                  Motherboard: Acer IPISB-AG Rev 1.04, LGA1155, H61 Express
                                  BIOS: P01-A1 dated 4 May 2012 (originally P01-A0 dated 26 Aug 2011, Bios webpage
                                  Bios Chip: Winbond 25Q32BVSIG (32Mbit, 4MB)
                                  CPU: Intel Pentium G620 65W (sandy bridge)
                                  New CPU: Intel Core i5-3470s 65W (ivy bridge)
                                  Using AFUWIN from within Windows 7 to flash BIOS
                                    • 21002
                                    Post your bios backup
                                    • Monkfish
                                      • May 2021
                                      • 5
                                      • United Kingdom
                                      Please find attached P01-A1 which is my current bios that fails to recognise the new Intel Core i5-3470s ivy bridge CPU.
                                      Is this what you wanted? So long since I have done any of this stuff.
                                        • 21002
                                        If you can source an 8MB bios chip 25Q64 ,flash this bios,or try the other 8MB one already posted
                                        https://www.bios-mods.com/forum/Thre...-CPU-whitelist
                                        • James194zt
                                          Acer Nitro 50-640E Corrupted BIOS Dump
                                          by James194zt
                                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                          04-28-2025, 03:29 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          Yesterday, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • ZOrd_Z
                                          Acer Predator P03-650 bios DUMP.
                                          by ZOrd_Z
                                          I need a bios dump to a Acer Predator P03-650 board.
                                          Or to convert the .CAP file o a file to flash.
                                          Thank's......
                                          10-29-2024, 12:06 PM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
