Emaxx EMX-A70FM2+ICAFE desktop board need bios
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working bios for this EMAXX BOARD. Board id:EMX-A70FM2+ICAFE VER:1.0 please
    • 21841
    Re: Emaxx desktop board need bios
    here, ver 1 and 2.
    EDIT: New link to bios downloads -> https://www.emaxxtech.com/elementor-321/
    • String2016
      • Nov 2015
      • 2238
      • philippines
      ver 1 its working but it takes 5minutes to wait for the display comes
        • 21841
        Its a virgin bios straight from emaxx ,your problem is somewhere else , hard drive, optical drive bad or SATA cables most likely fault.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          already removed all the cable but still 5mins to take display does this onboard video have problem?
          • p7comuter
            • Mar 2015
            • 75
            • Philippines
            try this bro
            • techcare
              • Nov 2017
              • 18
              • KOREA
              Someone here who have EMX-A70FM2+iCafe BIOS.bin file.Thanks in Advance
              • techcare
                • Nov 2017
                • 18
                • KOREA
                I have saved the bios bin file from a working motherboard i hope it would help you guys.
                • pykra1
                  • May 2021
                  • Philippines
                  Thank you so much, I will use it on my motherboard.
                  • yborann
                    • Jul 2010
                    • 5
                    • Philippines
                    Thanks Everyone. My motherboard is working again!!!..Its been awhile this motherboard emx a70fm2 was dead ..Im glad I found this site..agaim many thanks..bios ver 2. works for me..
                    • jocteza1
                      • Aug 2021
                      • Philippines
                      Thank you, this is working of my Emaxx board same model.
                      • lagytube
                        • Mar 2021
                        • philippine
                        Re: Emaxx EMX-A70FM2+ICAFE desktop board need bios
                        Need bios EMX-A70FM2+ICAFE VER:1.2 thank you
                          • 21841
                          EMX-A70FM2+ICAFE Bios from the support site https://drive.google.com/drive/folde...cg&usp=sharing
                          • ME Tech
                            • Aug 2019
                            • 26
                            • Philippines
                            sir board of EMAX version is this? it won't still display
                              • 21841
                              see the link at post #13 to the emaxx support site
                              • ME Tech
                                • Aug 2019
                                • 26
                                • Philippines
                                can i flash bios UPS file direct to chip using rt809f without converting it to BIN file?
                                  • 21841
                                  If the RT809F will read the file yes.If not just rename the file extension from .UPS to .bin or .rom
                                  • eteng25
                                    • Mar 2014
                                    • 9
                                    • philippines
                                    try this
                                    • yandria123
                                      • Mar 2022
                                      • Philipphines
                                      I need a bios for this EMAXX BOARD. Board id:EMX-A70FM2+ICAFE VER:1.0 please
                                      I really need Please help me
                                        • 21841
                                        Did you read the whole thread. See post #2 and #13
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                        • AustinCER
                                          HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                                          by AustinCER
                                          I currently have an HP ENVY Desktop TE01-1214
                                          S/N -
                                          2MO22342GX
                                          Motherboard - L75365-001
                                          BIOS Chip - W25Q128JVSQ
                                          Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                                          Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                                          04-25-2025, 05:56 PM
                                        • edward card
                                          BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                                          by edward card
                                          I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                                          Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                                          Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                                          Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                                          10-06-2025, 05:41 AM
