ASRock H61M-DGS dump required.
  • diif
    • Feb 2014
    • 6978
    • England
    As per title, I'm looking for a dump of of an ASRock H61M-DGS.
    Thank you.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: ASRock H61M-DGS dump required.
    Dump found.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      How about sharing it, so someone else searching for it can find it.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • javl9066
        • May 2020
        • Santiago
        Hello, can you help me. I need dump for asrock h61m-dgs, thanks
        Saludos, Villa
        • piernov
          • Jan 2016
          • 4439
          • France
          Download from official Asrock website.
          • gabrieljma1
            Request: Full BIOS dump for ASRock Z790-CX (DDR5)
            by gabrieljma1
            I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
            The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
            I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
            10-08-2025, 03:32 PM
          • Andreas_de
            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
            by Andreas_de
            Hello!
            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
            04-12-2025, 10:38 AM
          • khanhtq0
            Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
            by khanhtq0
            I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
            I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
            I suspect the original Intel ME and descriptor...
            08-06-2025, 02:14 AM
          • subzerillo
            Asrock H510M-HDV/M.2 SE bios dmi area from dump
            by subzerillo
            Hello.
            I'm wondering how can I check and extract de dmi area from a bios backup.
            I know it depends on the brand and model of the motherboard. Is there some guide that could help me understand and extract the dmi from the original bios dump to a new bios file.
            The motherboard is H510M-HDV/M.2 SE
            Attached is:
            h510m is the dump bios
            h510mhms1 is the downloaded bios from the website...
            10-09-2025, 02:23 PM
          • jovani1989
            HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
            by jovani1989
            HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...
            06-11-2025, 01:54 PM
