Dump bios gigabyte /ga-h61m-s1-rev.2.1 tested -good
Bios --ga-h61m-s1-rev.2.1
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
Channel: BIOS Requests ONLY!
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
- Loading...
