Bios Request MSI H61M-P23(B3)
  • ScorpioMan86
    • 94
    • South Africa
    Hi Guys,
    I would like to request a bios rom/bin file for MSI H61M-P23(B3), MS7680.
    I need the file i can write directly to the chip, i cant extract the exe file.
    Thank you
    • 21635
    Re: Bios Request MSI H61M-P23(B3)
    Try this one,and give feedback .
    • ScorpioMan86
      • 94
      • South Africa
      Hi There,
      Thank you for the bios but the board doesnt dsplay or beep still. it switches on and powers off "normally".
      Its MS 7680 ver 3.2, unsure if that makes a huge difference vs the bios you suggested.
      I will spend a bit more time on the board in the coming days to see what else could be wrong.
        • 21635
        Try this older version bios .
        • MASTERTECHNICIAN
          • Jan 2022
          • Philippines
          Pa help po sir i need bios bin file for MSI H61M-P23 (B3) Version 3.2
          • peste
            • 13370
            • ROMANIA
            try post #4..don't forget to make a copy of the original bios before writing the bios chip..
            • peste
              • 13370
              • ROMANIA
              sir pa help po ma revive or ma recover itong corrupted bios bin file po
              try this..
              https://www.msi.com/Motherboard/H61MP23_B3/support
              • MASTERTECHNICIAN
                • Jan 2022
                • Philippines
                I try already sir but the motherboard cannot power on
                • damithemail
                  • Sri Lanka
                  Hi....
                  i need your help for getting a MSI H61M-P25 (B3) .bin bios
                  MS-7680 VER : 5.1
                  and many thanks
                  • ScorpioMan86
                    • 94
                    • South Africa
                    Originally posted by damithemail
                    Hi....
                    MS-7680 VER : 5.1
                    and many thanks
                    Please try the attached and confirm if it works ?
                    • litsnsirn
                      • Dec 2021
                      • 29
                      Sorry to dig this back up, but I grabbed the wrong file above and now my H61M-P25 thinks its a H61M-P23. Is there a big enough difference to desolder the chip from the board again and flash it with the P40 bios?
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • survivalbloke
                        Unable to extract bios file from Lenovo bios exectuable
                        by survivalbloke
                        I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                        Code:
                        "innoextract 7wcn38ww.exe"
                        it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                        The trouble I'm having is that I'm not getting the newly...
                        06-12-2024, 07:55 AM
                      • survivalbloke
                        Unable to extract Lenovo BIOS file from installer
                        by survivalbloke
                        I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                        I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                        How can...
                        07-16-2025, 03:21 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
