Msi ph61-p33 (b3) ms-7732 ver 1.1 bios
  • kadi144
    • Aug 2015
    • 690
    • algerie
    HI all members
    i need a working bios of MSI PH61-P33 (B3) MS-7732 VER 1.1
    merci in advance
    • 21850
    Re: Msi ph61-p33 (b3) ms-7732 ver 1.1 bios
    here you go .
    • kadi144
      • Aug 2015
      • 690
      • algerie
      thanks
      i will try it
      • kadi144
        • Aug 2015
        • 690
        • algerie
        thanks
        i will try it
        • kadi144
          • Aug 2015
          • 690
          • algerie
          my bios =4MB NOT 8MB
            • 21850
            Yes it should be 4MB, the software i used to extract the exe copied the same bios twice into an 8MB bin. Try this new one .
            The wrong 8MB bios has had 17 downloads so far, why don`t they check to see if the bios is working first
            • kadi144
              • Aug 2015
              • 690
              • algerie
              MANY THANKS
              i try it
              • particlesolo
                • Apr 2020
                • 13
                • indonesia
                many thanks sir.. it worked for me,, 4mb,, .. have lucky day
                  • 21850
                  You`re welcome .The wrong bios had 57 downloads so now its been deleted,they should have read the whole thread
                  • zPwN!
                    ENOVA NE14I310 XU133t rev 1.3 working BIOS
                    by zPwN!
                    Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
                    Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
                    System SKU NE14I310
                    BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
                    Motherboard XU133T rev 1.3
                    Serial Number IPNBI3X240SM2A01095
                    Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
                    RAM 8.00 GB
                    NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
                    01-03-2025, 01:03 AM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • joven016
                    Lenovo Ideapad S145 need working bios HELP!!
                    by joven016
                    Problem is blinking power led only
                    i don't know exactly if it's s145-15igm or s145-14igm
                    have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                    Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                    Already tested some of posted bios here
                    S145-14igm - success but invalid serial and not booting on OS
                    S145-15igm - success with serial and some other info in bios but still not booting on OS
                    already tried installing new windows but always booting on bios setup
                    windows installer flash drive detected on...
                    08-21-2025, 10:55 PM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • Sparklingx
                    CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                    by Sparklingx
                    So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                    So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                    now all...
                    08-29-2024, 01:53 PM
