This is a desktop motherboard.
G31T-M7 Rev 7 bios bin file needed
Tags: None
Re: G31T-M7 Rev 7 bios bin file needed
why dont you check the manufactors website?
desktop motherboards are usually the easiest to find..
here:
http://www.ecs.com.tw/ECSWebSite/Pro...0-LL-Intel-RR-Last edited by ziggster; 03-12-2019, 09:26 AM.
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by CityminHi all,
S/N : 5RNK9FFT70...-
Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
