need dump acer h61h2-ad v: 1.0
  • salim deia
    • May 2017
    • 18
    • algeria
    thnx.
    • 21204
    Re: need dump acer h61h2-ad v: 1.0
    Post your bios backup .Do you want the win 7 or 8 bios .
    • salim deia
      • May 2017
      • 18
      • algeria
      http://ww******************d.bin/file
      i have changed the battery 3v . But does not save settings in bios setup.
      tnx a lot.
        • 21204
        Try this one.
        • salim deia
          • May 2017
          • 18
          • algeria
          SMDflea
          its same erreur.
            • 21204
            The bios is straight from acer, so should not be a bios problem.Check the traces running from the bios battery,check caps ,diode - maybe bat54c .
            • raedinformatique
              • Feb 2018
              • 25
              • algeria
              Originally posted by SMDFlea
              Try this one.
              Thank you it is OK in Acer veriton x2611G with motherboard H61 H2-AD.
              Thank you again.
              • TIXOU14
                • Aug 2020
                • 15
                • TIARET
                Originally posted by smdflea
                try this one.
                your dump is 8 mb in my bord is chip of 4mb
                • TIXOU14
                  • Aug 2020
                  • 15
                  • TIARET
                  Need bios of 4mb
                  • kosmonaft
                    • Mar 2016
                    • 7
                    • Россия
                    So, any correct dump at 4mb?
                    • rex98
                      • Feb 2023
                      • 1281
                      • Mandaue CEBU, Philippines
                      no display. please fix 4MB BIOS DUMP
                      • peste
                        • Dec 2016
                        • 12973
                        • ROMANIA
                        try...
                        • nassimhamdi
                          • Feb 2016
                          • 150
                          • algeria
                          hi i nedd h61h2-ad v: 2.0
                        • James194zt
                          Acer Nitro 50-640E Corrupted BIOS Dump
                          by James194zt
                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                          04-28-2025, 03:29 PM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • ZOrd_Z
                          Acer Predator P03-650 bios DUMP.
                          by ZOrd_Z
                          I need a bios dump to a Acer Predator P03-650 board.
                          Or to convert the .CAP file o a file to flash.
                          Thank's......
                          10-29-2024, 12:06 PM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
