Asus h81m-k desktop board bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need a working bios for ASUS H81M-K DDR3 DESKTOP BOARD please
  • narsil
    Enas
    • Dec 2017
    • 83
    • france
    Re: Asus h81m-k desktop board bios needed
    try this
    • Romy2018
      • Sep 2018
      • 174
      • japan
      thanks but still the same problem turns on then a second shuts off
        • 20477
        bios .
        • Romy2018
          • Sep 2018
          • 174
          • japan
          thanks smdflea i will try your bios and update soon
          • Romy2018
            • Sep 2018
            • 174
            • japan
            i flashed the bios still the same issue turns on fan spins then shuts off.maybe this is not a bios issue
              • 20477
              The bios is straight from asus, not a bios issue.
              • mahmoodjavan
                Banned
                • Mar 2018
                • 584
                • iran
                PLZ TEST WORKING BIOS
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  it's the bios issue, check if the unit processor is powered
                  • jhomhar08@gmail.com
                    • Jul 2018
                    • 7
                    • philippines
                    working bios thanks sir the exact bin file is 8,192 not 8194
                    • redcup1999
                      • Dec 2020
                      • United Kingdom
                      Thanks - this helped me out of a hole - I've managed to get my H81M-K going again.
                      • Bloodme23
                        • Apr 2021
                        • 17
                        • Philippines
                        I'm having issues on a pc the motherboard is h81m-k rev 1.01 too i successfully flashed the bios because its my friends motherboard he does hackintosh and did something wrong and the tool that i used is CH341A Mini Programmer everything went smoothly and i verified the bin file first and it says its the same data and all that. but when i plugged the bios chip back the pc does turn on but there's no display, no beeps, no light codes either. i tried changing ram sticks that i know and tested that are good ones but still no display. i used gt 1030 and radeaon hd 5870 but it still doesnt show display... what could be wrong here?
                        • bel77
                          • May 2013
                          • 33
                          • jordan
                          try this working tested
                          • bel77
                            • May 2013
                            • 33
                            • jordan
                            h81m-k
                            test its working good
                            • german_chimy
                              • Jul 2021
                              • argentina
                              This model worked perfectly. Tested on Model K
                              • taroo
                                • Sep 2021
                                • 16
                                • myanmar
                                Please let me know more more, i am a very first test with Bios writing
                                This error occur
                                Verifying memory...
                                Verification error on address: 00000000
                                Execution time: 0:00:00
                                • 2010fafa
                                  • Oct 2016
                                  • Tajikistan
                                  Thanks bro for working bios!!!
                                  • ductranvinh
                                    • Dec 2021
                                    • 123
                                    • Republic of Vietnam
                                    CH341a Pro u need change type file ".Cap" to ".Bin". Because it's cheap tool and not support "*.Cap". U can search on gg how to change .cap to .bin. Then u go Asus web u download newest bios. Asus bios file always ".Cap"
                                    PC work for schemaltic:
                                    Mainboard: Gigabyte Z68XP-UD4
                                    CPU: I3-3240
                                    Ram: 16Gb
                                    Graphic Card: GTX 1050Ti zotac 4Gb Mini
                                    SSD: 120Gb
                                    HDD: 2Tb
                                    • masray
                                      • Apr 2022
                                      • indonesia
                                      permission for download and share,, it's work for me..thanks..
                                      • s_henya
                                        • Jan 2011
                                        • 480
                                        • Israel
                                        I have the same motherboard ASUS H81M-K with the exact same issue, power on for a sec and shuts off.
                                        i didn't try bios reflash since i suspect it's a HW issue.
                                        did you manage to solve the problem or should i just order a new board?
                                        if anyone has an idea what can be the problem please let me know.
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • exerion5000
                                          Bios Needed For Asus X515EA Pcb X415EA R2.0
                                          by exerion5000
                                          Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                          Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                          02-17-2025, 01:34 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
