Asus h81m-k desktop board bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need a working bios for ASUS H81M-K DDR3 DESKTOP BOARD please
  • narsil
    Enas
    • Dec 2017
    • 84
    • france
    Re: Asus h81m-k desktop board bios needed
    try this
    • Romy2018
      • Sep 2018
      • 174
      • japan
      thanks but still the same problem turns on then a second shuts off
        • 21861
        bios .
        • Romy2018
          • Sep 2018
          • 174
          • japan
          thanks smdflea i will try your bios and update soon
          • Romy2018
            • Sep 2018
            • 174
            • japan
            i flashed the bios still the same issue turns on fan spins then shuts off.maybe this is not a bios issue
              • 21861
              The bios is straight from asus, not a bios issue.
              • mahmoodjavan
                Banned
                • Mar 2018
                • 584
                • iran
                PLZ TEST WORKING BIOS
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  it's the bios issue, check if the unit processor is powered
                  • jhomhar08@gmail.com
                    • Jul 2018
                    • 6
                    • philippines
                    working bios thanks sir the exact bin file is 8,192 not 8194
                    • redcup1999
                      • Dec 2020
                      • United Kingdom
                      Thanks - this helped me out of a hole - I've managed to get my H81M-K going again.
                      • Bloodme23
                        • Apr 2021
                        • 23
                        • Philippines
                        I'm having issues on a pc the motherboard is h81m-k rev 1.01 too i successfully flashed the bios because its my friends motherboard he does hackintosh and did something wrong and the tool that i used is CH341A Mini Programmer everything went smoothly and i verified the bin file first and it says its the same data and all that. but when i plugged the bios chip back the pc does turn on but there's no display, no beeps, no light codes either. i tried changing ram sticks that i know and tested that are good ones but still no display. i used gt 1030 and radeaon hd 5870 but it still doesnt show display... what could be wrong here?
                        • bel77
                          • May 2013
                          • 33
                          • jordan
                          try this working tested
                          • bel77
                            • May 2013
                            • 33
                            • jordan
                            h81m-k
                            test its working good
                            • german_chimy
                              • Jul 2021
                              • argentina
                              This model worked perfectly. Tested on Model K
                              • taroo
                                • Sep 2021
                                • 16
                                • myanmar
                                Please let me know more more, i am a very first test with Bios writing
                                This error occur
                                Verifying memory...
                                Verification error on address: 00000000
                                Execution time: 0:00:00
                                • 2010fafa
                                  • Oct 2016
                                  • Tajikistan
                                  Thanks bro for working bios!!!
                                  • ductranvinh
                                    • Dec 2021
                                    • 135
                                    • Republic of Vietnam
                                    CH341a Pro u need change type file ".Cap" to ".Bin". Because it's cheap tool and not support "*.Cap". U can search on gg how to change .cap to .bin. Then u go Asus web u download newest bios. Asus bios file always ".Cap"
                                    PC work for schemaltic:
                                    Mainboard: Gigabyte Z68XP-UD4
                                    CPU: I3-3240
                                    Ram: 16Gb
                                    Graphic Card: GTX 1050Ti zotac 4Gb Mini
                                    SSD: 120Gb
                                    HDD: 2Tb
                                    • masray
                                      • Apr 2022
                                      • indonesia
                                      permission for download and share,, it's work for me..thanks..
                                      • s_henya
                                        • Jan 2011
                                        • 483
                                        • Israel
                                        I have the same motherboard ASUS H81M-K with the exact same issue, power on for a sec and shuts off.
                                        i didn't try bios reflash since i suspect it's a HW issue.
                                        did you manage to solve the problem or should i just order a new board?
                                        if anyone has an idea what can be the problem please let me know.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • DynaxSC
                                          ASUS STRIX Z490-F GAMING - No POST, stubborn board
                                          by DynaxSC
                                          I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                                          The situation looks like this:
                                          After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                                          1. RTC oscillates normally (32.768KHz).
                                          07-08-2022, 05:45 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • ShadowAi12
                                          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                          by ShadowAi12
                                          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                          • The board enters a "ready to power on" state after plugging in the PSU.
                                          • Pressing the power button increases power draw.
                                          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                          Measurements:
                                          (taken after pressing the power button, while the board is attempting to start)
                                          • H_SKTOOC#
                                          06-11-2025, 01:05 PM
