I need a working bios for ASUS H81M-K DDR3 DESKTOP BOARD please
Asus h81m-k desktop board bios needed
Re: Asus h81m-k desktop board bios needed
bios .Attached FilesComment
PLZ TEST WORKING BIOS
Attached FilesLast edited by SMDFlea; 01-13-2023, 08:49 AM.Comment
Thanks - this helped me out of a hole - I've managed to get my H81M-K going again.Comment
I'm having issues on a pc the motherboard is h81m-k rev 1.01 too i successfully flashed the bios because its my friends motherboard he does hackintosh and did something wrong and the tool that i used is CH341A Mini Programmer everything went smoothly and i verified the bin file first and it says its the same data and all that. but when i plugged the bios chip back the pc does turn on but there's no display, no beeps, no light codes either. i tried changing ram sticks that i know and tested that are good ones but still no display. i used gt 1030 and radeaon hd 5870 but it still doesnt show display... what could be wrong here?Comment
try this working testedAttached FilesComment
CH341a Pro u need change type file ".Cap" to ".Bin". Because it's cheap tool and not support "*.Cap". U can search on gg how to change .cap to .bin. Then u go Asus web u download newest bios. Asus bios file always ".Cap"PC work for schemaltic:
Mainboard: Gigabyte Z68XP-UD4
CPU: I3-3240
Ram: 16Gb
Graphic Card: GTX 1050Ti zotac 4Gb Mini
SSD: 120Gb
HDD: 2Tb
I have the same motherboard ASUS H81M-K with the exact same issue, power on for a sec and shuts off.
i didn't try bios reflash since i suspect it's a HW issue.
did you manage to solve the problem or should i just order a new board?
if anyone has an idea what can be the problem please let me know.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by DynaxSCHi,
I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
The situation looks like this:
After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
1. RTC oscillates normally (32.768KHz).
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by ShadowAi12Hi,
I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.- The board enters a "ready to power on" state after plugging in the PSU.
- Pressing the power button increases power draw.
- Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
(taken after pressing the power button, while the board is attempting to start)- H_SKTOOC#
06-11-2025, 01:05 PM - Loading...
