Need Schematic Asus AIO PC
  • kodox
    • Jul 2017
    • 322
    • Indonesia
    I need schematic or boardview for asus all in one pc, board model V200IB Rev.1.3
    it's hard to remain on after pressing power button, only last for 2-3 seconds then off but sometime it succesfully boot to window, i've been measured all inductor on the board (when it's hard to power on) and it's all there, no missing voltages.
    strange thing happen when i measure voltage near the power button, it's fluctuated from 1.2v-3.3v and sometimes zero!!! when that voltages fluctuated the pc powered on by itself then turned off again. i've tracked the power button line to EC to try manually pull that line low without power button board attached to flex cable, the pc manage to power on for a long time but no display on screen.
    someone had an idea where to look?
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: Need Schematic Asus AIO PC
    Probably this series still fresh from oven, I think currently not available.
    Seem only board of power button have issue.
    Is there a part which kind similar of LID ic on power button connector?
    • kodox
      • Jul 2017
      • 322
      • Indonesia
      @on/off
      i think there's no ic on power button board, there's only resistor and capacitor. i'll upload the picture later
      • TimeRabbit07
        Asus FX517ZC charges but power button does nothing
        by TimeRabbit07
        Hi all!
        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
        Here are its various numbers and identifiers:
        Model short: FX517Z
        Model long: FX517ZC-HN114W
        SN: NANRCX01S57842E
        CN: 3SDB 12M
        MFD: 2022-10
        Motherboard model: DA0NJLMBAE0 REV E
        Symptoms:
        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
        History so far:
        The...
        09-04-2024, 05:48 PM
      • themosttogain
        HP Envy 13-BA1565na with intermittent power button
        by themosttogain
        Hope someone can give me some suggestions on this because i'm at my wits end with it...
        I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
        Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
        07-12-2024, 03:03 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • myth77
        Asus Gl753, gl553, fx553 keyboard power button not working
        by myth77
        I have i think 4 dead keyboards from laptops in the title...they are very similar...almost the same...and all of them have not working power buttons. All other keys are working...but when you press power button it doesnt short 3.3v to gnd...so you can only do it manually on the keyboard conector with tweezers or similar. I inspected in every detail ribbon cable that is going to the motherboard connector and removed power key button from keyboard to see anything wrong there, but all seems perfect.
        Has anyone with more expirience figured where is that power button line getting broken? because...
        07-13-2023, 12:30 PM
      • reessi
        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
        by reessi
        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
        No corrosion any where!
        Tried a replacement power button off ebay and the same.
        Very occasionally it will work with the power button connected!
        Same results with or without the battery.
        Can it be a fault with the Audio board or the mainboard?
        The touch Id assembly connects through the Audio board first then to the Mainboard.
        Flex...
        06-26-2024, 03:31 PM
