Compaq SG3-350FR H-AIRA-RS780L-uATX BIOS Request
  • piernov
    • Jan 2016
    • 4435
    • France
    I'm looking for H-AIRA-RS780L-uATX BIOS for a non-POSTing Compaq SG3-350FR desktop computer.
    • 20818
    Re: Compaq SG3-350FR H-AIRA-RS780L-uATX BIOS Request
    i have this one,i got it from E-Spec, its for a different model, you can try it or merge with backup bios.
    h-alpinia-rs780l-uatx ver.1.01
    • piernov
      • Jan 2016
      • 4435
      • France
      Aira looks like a stripped down version of Alpinia looking at pictures, so I'm gonna try it, thanks.
      I would still prefer to have the correct BIOS if anyone has it.
      • piernov
        • Jan 2016
        • 4435
        • France
        Tried to flash directly your dump, it didn't work.
        Attached is old dump.
        Any idea or anyone has the correct dump?
        (might be that the issue isn't the BIOS…)
          • 20818
          Can only find it on vlab. http://*******/viewtopic.php?f=44&t=41248 .If you join vlab and ask ,he may send it to you too.
          • piernov
            • Jan 2016
            • 4435
            • France
            Bought it, sadly it didn't fix it. What was I expecting anyway?
            Attached is the "good" downloaded BIOS.
              • 20818
              Have you tried the IO chip ,it looks like an ITE ,i can`t see part number though. Heres a list of a few replacement IOs for desktop boards
              https://sscomputerbth.blogspot.com/p...therboard.html
              • piernov
                • Jan 2016
                • 4435
                • France
                I got proper VCore and this is an AMD board. Way more chances of the northbridge being dead than the SIO. I don't want to waste my time on this because I know that the chances of it being worthless are too high (ie. it can't be fixed).
                Thanks for the help again anyway.
                  • 20818
                  No problem . B.t.w. ,the "good" bios is probably ok,the motherboard is the same, a Foxconn 2AAF 1.00
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    Ok so I shouldn't have but I came back to this board. BIOS was not being read at all.
                    I heated the northbridge (215-0674042) to 200°C, the board booted, I cried because it's another board that goes to the thrash bin due to a crappy northbridge. Thanks ATi/AMD.
                    Can confirm that the BIOS is good though.
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
