need bios HP ProOne 600 G2 21.5-inch NonTouch All-in-One PC
  • mhd_mahad
    • Jun 2016
    • 61
    • egypt
    hi all i want dump for HP ProOne 600 G2 21.5-inch Touch All-in-One PC quickly please
  • mhd_mahad
    • Jun 2016
    • 61
    • egypt
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: need bios HP ProOne 600 G2 21.5-inch NonTouch All-in-One PC
      post non working bios here
      • mhd_mahad
        • Jun 2016
        • 61
        • egypt
        Old bios
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Your bios fixed. Enjoy
          • mhd_mahad
            • Jun 2016
            • 61
            • egypt
            thanx bro
            • faysal
              • May 2015
              • 22
              • Pakistan
              can you please edit it for me also
              original file attached
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Try this. Whats your problem??
                • faysal
                  • May 2015
                  • 22
                  • Pakistan
                  system shows no display
                  now i am checking your fixed bios
                  • zkirac
                    • Dec 2014
                    • 5
                    • turkey
                    hi tried all dumps but all of them not working is there anyone have working dump ? for pro one 600 g2
                    • nyknemesis
                      • Aug 2012
                      • 86
                      • romania
                      Hello i have the same problem, non of the bios-es above work, this aio doesn't post, can any one help with a bios dump or fix the one atached?
                      thank you.
                      • narsil
                        Enas
                        • Dec 2017
                        • 84
                        • france
                        You have to change it in any other type with the same size and discharge it
                        I have had this problem a lot with : sst25vf032b
                        • nyknemesis
                          • Aug 2012
                          • 86
                          • romania
                          you mean replace the bios chip with another and eraser whatever was on it and write one of the above?
                          because the dump i posted was from the original chip.
                          • narsil
                            Enas
                            • Dec 2017
                            • 84
                            • france
                            Yes, my brother, replace the chip with another, be the same size
                            Get one of the old motherboard
                            • nyknemesis
                              • Aug 2012
                              • 86
                              • romania
                              i wil try to find one, i will post the result, thanks for youre time.
                              • nyknemesis
                                • Aug 2012
                                • 86
                                • romania
                                helo guys. problem solved, you have to clear me region from the bios (Google how ) NONE of the bioses posted here are cleared. i have atached a clear bios but if it dosen't work for you download the HP ProOne 600 G2 fixed posted above, and clear it you're self it will work. after boot you will have a msg booting to factory mode 30 seconds, just update bios normaly in windows or from bios.
                                • c_vasiloiu
                                  • Oct 2019
                                  Hi
                                  I have a HP ProOne 600 G2 that is beeping 4 times with power led flashing. I do not know if the bios is the root cause of the issue. I have attached the bios that I have read from a Winbond W25Q128BV chip.
                                  Please confirm if the bios is a valid one.
                                    • 21841
                                    Originally posted by c_vasiloiu
                                    Hi
                                    Try this bios .
                                    HP ProOne 600 G2 21.5-inch Non-Touch All-in-One PC
                                    • c_vasiloiu
                                      • Oct 2019
                                      Thank you @SMDFlea for the prompt reply.
                                      I have tried the bios that you sent, but the behavior is the same. There are 3 long beeps(led on the power button is flashing red 3 times) followed by 4 short beeps((led on the power button is flashing white 4 times) and the fans are not spinning. This HP ProOne 600 G2 has suffered a power surge, together with other similar PCs. For some of these PCs, I have found some short-circuits on the power supply phases for processor, that have disappeared after I have removed the processor from his socket.
                                      Is it possible that the beeps are showing a hardware failure for some chip-set on the motherboard or even some hardware failure of the processor itself?
                                      • c_vasiloiu
                                        • Oct 2019
                                        For the "beeping" board I have discovered the root cause of the beeps: The processor was missing. I have put a G3900 on this motherboard and it is working OK, also the bios from @SMDFlea.
                                        Does anybody know if the processor G4560 is working with this motherboard? I have found on Q150 chip set specs (on http://www.cpu-upgrade.com/mb-Intel_...ets)/Q150.html ), that it is supporting this processor.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
