bios for 820-2901-A
  • rookieme
    • Oct 2014
    • 397
    • Greece
    bios for 820-2901-A
    anyone can share a bios dump for 820-2901-A
    this was "repaired" by somebody
    now my issue is that doesn't work with the correct cpu but with lower ones
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Re: bios for 820-2901-A
    Here try this bios
    • rookieme
      • Oct 2014
      • 397
      • Greece
      thank you, will try and inform you
      • rookieme
        • Oct 2014
        • 397
        • Greece
        I've tested the bios but didn't solved my problem so I have somewhere else the issue.
        The issue is that by using the correct cpu I get memory error beep at boot.
        The cpu works ok at similar iMac.
        Also same issue with similar cpu.
        The strange is that I have the problem with i5 cpu.
        Once I tested a i3 from 21,5 iMac and worked!
        I can't figure out why doesn't work with the appropriet cpu.
        Luckily I have plenty of time from my customer...
        • rookieme
          • Oct 2014
          • 397
          • Greece
          ok, I solved my problem but I had some issues with the display [it was loosing backlight]
          It seems to work ok with the old bios I had so I uploaded it also just in case anybody needs to use it also.
          [make sure to program the correct S/N as now it has 12345678900]
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
