hi everyone i need a working bios for this desktop pc dell optiplex 380 the problem turns on but no display already tried replaced ram with good one but still no display changed processor still the same issue turns on fan spinning but no display
dell optiplex 380 bios needed
Tags: None
Re: dell optiplex 380 bios needed
please your service tag or try this from official web site....Attached Files -
your dump from Dell support web siteAttached FilesComment
I need the optiplex 380 service tag CNVDFQ1 bios. thank you. leave the original biosAttached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
- Loading...
